Dot 4 brake fluid
^^That thread explains the difference between DOT 3 and DOT 5, not DOT 3 and DOT 4.
DOT 4 basically has a higher boiling point than DOT 3 and is therefore more "high performance." It absorbs moisture more easily than DOT 3 though.
DOT 5 is totally different and should definitely not be used on any modern car with ABS. It cannot be mixed with any other type of brake fluid.
