Water in fuel sensor - Ford Truck Enthusiasts Forums
Old 08-26-2008, 04:07 PM
lionsteve lionsteve is offline
lionsteve is starting off with a positive reputation.
Does anyone have a step by step of how to replace the water in fuel sensor? Friends 03' light keeps coming on after draining and changing both filters. Thanks in advance.
Steve
Old 08-26-2008, 09:31 PM
Tim C's Avatar
Tim C Tim C is offline
Tim C is starting off with a positive reputation.
My 03 also used to set that light even after draining the housing and replacing the filters. I was told to remove the cover (the part with the 4 lines and the drain plug, ford calls it a fuel manifold) and clean the actual sensor with carb or brake cleaner. You'll need a new gasket (from the dealer) however. Make sure you dry it out good so no carb cleaner goes thorough the injectors. I believe the sensor is in the fuel manifold/cover. I pulled mine off, sprayed it cause it was full of some brown slimy stuff, blew it dry with compressed air, and reinstalled. That fixed my water light.
You just remove the 4 lines with the fuel line disconnect tool (available at most parts stores, kind of made like scissors), unplug the 1-2 wire connectors (depending on weather yours has the fuel heater) and remove the 4 bolts from the cover. Its been my experience that the fuel doesnt drain as long if the tank has a lower fuel level.
1997 Ford F53 Fuel level bubblehdsts 1987 - 1996 F150 & Larger F-Series Trucks 2 04-18-2013 10:04 AM
Torque for Water Outlet Bolts? Steina Explorer, Sport Trac, Mountaineer & Aviator 1 10-11-2011 04:49 PM
Erratic fuel gauge Steve91 1987 - 1996 F150 & Larger F-Series Trucks 5 12-06-2002 10:08 PM
fuel injector cleaning steve_ Bronco II 3 02-04-2002 10:02 PM
step-bumper hitch vs. receiver hitch Steve_Uzi 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 11-20-2000 06:03 PM
Tags
2002, 2006, 60, 60l, ford, fuel, located, powerstroke, problems, replace, sensor, tank, truck, water, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
