Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 08-26-2008, 09:47 AM
rlynch131 rlynch131 is offline
Garage is empty, add now
rlynch131 is starting off with a positive reputation.
2001 F250 5.4L Wont start!
Drove it home last night with no problems. Went to go to work this morning, and all she does is turn over. I checked the Fuel pump fuse, it's o.k. I don't hear any pump noise when I turn the key on, and when I checked the pressure port on the fuel rail, no fuel comes out. Checked power at the fuse block and when I turn the key on, 5.5V for about 5 seconds and then ~ 0.5V after that.
Any thing else I should check before I replace the pump?
thanks
  #2 (permalink)
Old 08-26-2008, 02:43 PM
Monsta's Avatar
Monsta Monsta is offline
2005 Ford Excursion
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Power to the pump itself, I suppose. Could be a break in the wire but I doubt it.
How many miles you got on it?
__________________
Ken
"Socialism, like the ancient ideas from which it springs, confuses the distinction between government and society. As a result of this, every time we object to a thing being done by government, the socialist concludes that we object to its being done at all. " -The Law, Frédéric Bastiat, 1850
  #3 (permalink)
Old 08-26-2008, 07:06 PM
elmo8641 elmo8641 is offline
elmo8641 is starting off with a positive reputation.
you should have 12volts, not 5.5. i would double check that. if it is ok then i would check the fuel pump shut off switch. it is under the dash by the pass kick panel. then check power at the pump. if you have power then the fuel pump is bad. if you did have 5volts at the fuel pump fuse then you have a problem in the fuse box.
__________________
2003 f-250sd 4x4 4.10 5.4L
1994 cobra w/ trickflow heads, 10lb turbo
  #4 (permalink)
Old 08-26-2008, 07:27 PM
I checked the cut off switch, it's o.k.
I thought 5.5V was a bit strange, could it be the fuel pump relay contacts being bad?
Would there be any problems jumping 12V to the fuse to see if I get pressure?
Where is the relay located at?
Thanks to all for your assistance!!
Tags
2001, 54, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
