i have a 93 7.5l and was wondering what was the easiest way to make more power out of it it already has a straight pipe and k/n filter but i want to see at least 400 horse is that doable on my engine or not without getting a cam or supercharger
All you need to add to the trucks fuel system to run a carb is a fuel pressure regulator set to about 5.5 psi. Be sure to use a regulator the returns fuel to the tank so the pump stays cool. Then of course the adapter plate for the EFI manifold and the carb.
