You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I recently installed a CAI kit on my V10 - there was a provision for a seperate IAT, but on my V10, there isn't one.
I believe the intake air temp is done with the MAF on my '01.
But if there's a seperate IAT for your year, it would be in the air box, or just after it in the intake tube.
That code you posted means "intake temp high" - meaning the sensor isn't necessarily bad (code would say "circuit" in it), just that the air intake temp is reading too high.
Might have a dirty MAF if it's reading it off the MAF.
__________________
- art k. - Moderator for the Superduty, V10, 6.2L and FE forums
'13 Taurus SHO 3.5L Ecoboost w/Perf Pkg
'01 F250SD SC SB XLT V10 4x4 Volant CAI Hedman headers 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see. ®
I just cleaned the MAF last week with MAF cleaner. I got rid of the stock cone and put an after market one on their. Its off my buddies 04 mustang, he gave it to me because he got a S/C kit for it and the kit came with a intake. So anyways once we installed the kit, we realized that he needed to use the MAF that was on my truck (the one that he gave me with the cone) so i had to take it off. I drove around without a MAF for 3 days until i put the stock one back on. The stock one is on now but with the aftermarket cone still on their. After i hooked up the stock MAF, i found that it was still throwing a CEL. So i took it up to Autozone and the codes that i listed are what they found.
BTW, its a 01
__________________ 2006 Ford F350 Crew Cab Long bed, 4x4, 6.0L PSD
2006 F150 Ext cab black (traded in on F350)
2001 Ford Excursion, 4x2, 6.8L V-10, 4" lift, 33" BFG A/T (Totaled, May 2009 RIP)
With all that mucking around, reset the PCM and drive it for a few days and see if it comes back.
__________________
Founds this on the site, hope it helps narrow down the problems for yea
"The P0113 code means your Intake Air Temperature (IAT) sensor is sending a voltage signal back to the PCM that is too high (over 4.6 volts)
As noted, the IAT is a thermistor device in which resistance changes with temperature. The electrical resistance of a thermistor decreases as the temperature increases, and increases as the temperature decreases, (proportionally in each case). This varying resistance affects the voltage drop across the sensor terminals, which allows for a voltage signal to be sent back to the PCM corresponding to temperature.
The voltage signal that is sent back to the PCM is equal to the Reference Voltage (VRef, 5 volts) minus the aforementioned voltage drop across the fixed resistor. That is why an open in the circuit between the PCM and the IAT will result in "too high" voltage signal at the PCM (i.e., 5 volts). In addition, corrosion in the circuit would tend to add resistance and hence result in higher-than-normal voltage at the PCM because of the signal being based on voltage drop.
In any case, if the circuit checks out OK, then it's either the IAT sensor at fault, or the PCM."
__________________
99 F-250 Lariat V8 SC
02 CAT 420D
10 Nav L "OOOOOuuuuuu the party bus"
05 CAT 302.5
04 25' featherlite gooseneck
13 F-550 XL 6.7PD(4.88 gears?!?! thats serious)
I didnt have time to unhook my battery cables over the past couple days (busy with work and FF school) So i just let the check engine light stay on. On the way to the FF acadmey today, i got into my truck and turned it on and the check engine light was off . Its been off ever since i got into the car this mornin. Thanks for the helpful tips!
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
