Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-23-2008, 08:42 AM
swflagn swflagn is offline
Garage is empty, add now
swflagn is starting off with a positive reputation.
5th Gear?
I'm getting ready to buy an 08 Expy EL. I'm getting the HD Towing package for towing my boat (3000lbs). My question....Is there anything you can buy/do to keep the transmission in 5th gear while towing? It seems to me that this gear would be perfect for the highway.
Soon to be a former Suburban owner.
  #2 (permalink)
Old 08-23-2008, 10:02 AM
SemperFiDevilDog SemperFiDevilDog is offline
SemperFiDevilDog is starting off with a positive reputation.
Keep it out of OD
  #3 (permalink)
Old 08-23-2008, 10:29 AM
chuck s chuck s is offline
chuck s is starting off with a positive reputation.
If you want massive fuel consumption and high engine RPM turn the OD off and the transmission won't shift higher than 4th. Why would anyone do this?
I tow my 5000 pound camper with OD on and she runs at 1800 rpm in 6th gear. Sometimes she'll down shift to 5th and less down to 4th. No point in running 4th gear all the time if you only need it 10% of the time.
HD Towing package gets you about 9000 pounds max capacity. 3000 pounds won't be much of a bother at all, our 5000 pounds barely is. I've monitored transmission and engine coolant temperatures and only trans temp shows any rise from normal driving and that by 10° or 15° at most. Engine coolant remains below 200°.
-- Chuck
  #4 (permalink)
Old 08-23-2008, 10:59 AM
Chuck, I do not want to tow in 4th. Just want to know if there is a way to keep the tranny locked in the first OD gear, fifth.
  #5 (permalink)
Old 08-24-2008, 01:57 AM
Monsta's Avatar
Monsta Monsta is offline
2005 Ford Excursion
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
There is no way (currently) to do that.
__________________
Ken
"Socialism, like the ancient ideas from which it springs, confuses the distinction between government and society. As a result of this, every time we object to a thing being done by government, the socialist concludes that we object to its being done at all. " -The Law, Frédéric Bastiat, 1850
  #6 (permalink)
Old 08-24-2008, 09:53 AM
The reply to the original message suggested turning OD off. That'd make you run in 4th gear. As noted there's no way to lock out 6th gear. Nor is there any reason to lock it out.
-- Chuck
Tags
2008, 4th, 5th, downshift, expedition, ford, gear, manual, trailer, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
