92 F-150 Tachometer Wiring
I have put a carbureted 460 in my 92 F150 in place of the 5.0 that came in it. Everything works fine except for the tachometer.
I tried hooking up a wire to the negative side of the coil like the 5.0 was wired but it did not work (the computer is still installed). Then I removed the instrument panel and determined which wire carries the signal to the tach. I then ran a bypass wire to the negative side of the coil. The tach now works but it reads about 20% high (at 60 mph actual RPM is 2700 but the tach indicates about 3400). Has anybody "been there-done that" yet? Any suggestions?
I can answer for the 80-86 factory tachometer which should be the same if 0-6K RPM. On the back of the tachometer should be four terminals which are marked as follows
Right side B G
Left side 0 8
These tachometers were internally identical to all series Fords with the exception of the face and mounting bracket. Applications were used for the I4, I6, and V8 engines. B is battery power, G is ground 0 is either a shunt for I4 along with 8 or used alone for I6 application, else use 8 for V8 leaving 0 open.
Right side B G
Left side 0 8
Rockworthy
08-15-2015 09:24 PM
cyris426
30
11-23-2014 06:25 PM
cyris426
01-17-2014 07:27 AM
