Ported Vacuum Switch Temp Rating? - Ford Truck Enthusiasts Forums
Old 08-22-2008, 05:16 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
1985 Ford F150
Carbureted 302 V8, AOD
Non-California emissions
The ported vacuum switch on my thermostat housing broke off and I am going to replace it. Can someone tell me what temperature rating it needs to be when it opens to allow vacuum through? I am getting confused trying to match it up because I don't see a part number on it and some of the after market switches have different temperature ratings.
The parts man over at my local Ford dealer doesn't even know what I am talking about, so that is no help.
Old 08-22-2008, 09:23 PM
plowpusher plowpusher is offline
plowpusher is starting off with a positive reputation.
its called a coolant controlled vacuum switch or CCVS and usually you can tell by the color but what does it go to? Usually one line feeds it and one is a vent with no hose and one goes to the component i.e. air cleaner,EGR,AIR pump ect. this may help some one find wich one it is or you can try to find the correct vacuum print on autozone's web sight to identify it.
Old 08-22-2008, 09:56 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Yes, you need to know what it is controlling if you want to guess at a replacement. Some of these switches allow vacuum through at the setpoint(like a egr system would) and some block the vacuum at the setpoint(like a exhaust heat riser system would)
GM had a simple color system too, and I have it memorized. These two units always did what I wanted for most applications. It was on a 79 Monte carlo with a 305. The yellow one turned vacuum off at about 100 degrees and went to the heat riser in the exhaust, and the purple one turned vacuum on at about 100 degrees and it went to the EGR system.
Old 08-23-2008, 10:02 AM
LARIAT 85's Avatar
Well, I thought it was for controlling the canister purge for the EVAP system, but according to the '79 forums (I did a search) it seems on some models it is there for ignition timing. It seems that the distributor advance hooks to the middle port of the ported vacuum switch, the bottom port goes to MANIFOLD vacuum, and the top port goes to PORTED vacuum. Yes, I know my truck is an '85 (with A/C), but almost all of the emissions equipment is gone and I have had to start from scratch on the vacuum locations.
http://www.ford-trucks.com/forums/41...ingamajig.html
http://www.ford-trucks.com/forums/27...8-f-150-a.html
Quote:
...the three port switch at the front was used to help cool the engine by advancing the timing and allowing the engine to increase rpm for better coolant flow.
Quote:
This setup would give no vacuum advance when the engine was cold, normal vacuum advance at normal operating temperature, and manifold vacuum when the engine was overheating (the manifold vacuum would cause a higher idle, thereby cooling the engine off).
Old 08-23-2008, 10:14 AM
quaddriver quaddriver is offline
quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.quaddriver has a very good reputation on FTE.
Its also caleld a 'TVS'( thermal vaccum switch). that one is for overheat conditions to very advance vacuum at all times to cool cylinder head temps. LMC does have it...
pull it out of the engine and look for a scribed number on the copper portion.
Hooking Up A Stock Ford Air Cleaner LARIAT 85 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 06-26-2016 08:25 AM
Simplifying the Vacuum System of a 390 crazy96863 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 07-25-2015 12:56 AM
Simplifying the Vacuum System of a 390 crazy96863 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-24-2015 11:09 AM
Ported Vac Switch 79FordBlake 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-31-2013 12:41 AM
temperature ported vacuum switch ? roadrash63 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 11-15-2012 07:15 PM
Tags
1980, carlo, color, colors, ford, monte, ported, switch, temp, trucks, vacume, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
