Another leaf spring question...
Well, I'm getting ready to put my leaf springs (rear) back together - the auxiliary springs "donated" a couple to replace my broken ones. On another thread, someone mentioned NOT to paint between the leafs. I plan on using the "liners", but can't think of a good reason not to paint them. Can anyone elaborate? I am planning on painting them with Chassis Saver, which is VERY slick, and VERY durable. With the liners, I just don't see a problem....
Thanks in advance,
R
Thanks in advance,
R
on
Thanks Vern! Even more affirmation!
The Chassis Saver is basically the same soup as the POR-15, so I'm sure I'll be alright. The rust is the main issue, I want to try to keep to a minimum. These ARE 57 year old used springs, after all.
When I'm done, I might go ahead and pull my fronts apart again, and do it to them...but maybe not - if they go, I'll probably replace them - hopefully, financially, it will be more feasible then.
R
R
