WVO conversion for B-100
I asked this in a thread a while ago. Since the time is getting close I thought I'd ask again and put it up for discussion.
Would a conversion kit work for running B-100 in the winter?
Basically using B-100 instead of WVO that way you wouldn't have to thin it with diesel in the winter. What do you guys think?
The only thing that you would need to do is add a heated fuel filter that warm and 12 volt heater to the bottom of the fuel tank to heat Biodiesel above 60 F.
Biodiesel Fuel Warmers & Accessories
OK, Now I'm confused (which is easy when you are an old fart like you and I) We heat BD over 100F when we are capturing Methanol or when we use Magnesol. Will that cause polymerization? What about if I heat to 150-160F to run vapors through condensor? Hope the move is going well. Keep in touch. Tom
It has to do with the amount of time it stays at temp.
The longer BD is held at increased temps the greater the chances to initiate polymerization. The more polymerization that occurs the greater the chances for even more polymerization.
It is a snowball rolling down hill.
By the way I think I resent that comment about "old farts" I just can't remember why.
So, bottom line, it's OK to heat BD to 150-160F as long as it is just to capture vapors and don't keep it there any longer than necessary. Right? How do I know if I polymerized my BD and what are the consequences? Don't get too technical now. I really am an "old fart". Tom
Speaking of "old farts" when I moved to a new residence a few years ago, I kept driving from work to my OLD house. I sure hope Don will be OK after he finishes moving. We may have to send him a GPS unit to make sure he makes it to the new house (him being an old fart you know). I really am an "old fart". Tom
Consequences would be plugging of small passages, injectors, and increased pressure on the fuel pump possibly pump failure.
On our 20,000 mi trip around the US and Canada last year in our 87 f250 we mostly ran svo, but used #1 and 2 with bio-d in varying blends as starting fuel. I did run several tanks of bio-d in my heated svo side without any apparent trouble.
Does bio-d polymerise (sp?) more readily than svo?
Mike
Mike
naturescape
Bio-diesel, Propane & Alternative Diesel Engine Fuels
11-10-2010 08:04 AM
FordTruckNoob
01-17-2008 12:09 AM
derherr65
66
04-23-2007 08:23 AM
mongo75
19
03-17-2007 09:53 PM
