You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Yes it would work, BUT.........You would not want to heat it to the temps that WVO users use. I wouldn't heat it past about 75-80 deg. Normal WVO systems run about 160-180 deg, and this could cause polymerzation/ oxydation of the bio.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
The only thing that you would need to do is add a heated fuel filter that warm and 12 volt heater to the bottom of the fuel tank to heat Biodiesel above 60 F. Biodiesel Fuel Warmers & Accessories
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
If I went with a filter heater and a tank heater whats keeps the fuel in the line from gelling when the truck sits over night or for 8-10 hours while at work?
OK, Now I'm confused (which is easy when you are an old fart like you and I) We heat BD over 100F when we are capturing Methanol or when we use Magnesol. Will that cause polymerization? What about if I heat to 150-160F to run vapors through condensor? Hope the move is going well. Keep in touch. Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler. 100% BIO
It has to do with the amount of time it stays at temp.
The longer BD is held at increased temps the greater the chances to initiate polymerization. The more polymerization that occurs the greater the chances for even more polymerization.
It is a snowball rolling down hill.
By the way I think I resent that comment about "old farts" I just can't remember why.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
Speaking of "old farts" when I moved to a new residence a few years ago, I kept driving from work to my OLD house. I sure hope Don will be OK after he finishes moving. We may have to send him a GPS unit to make sure he makes it to the new house (him being an old fart you know).
So, bottom line, it's OK to heat BD to 150-160F as long as it is just to capture vapors and don't keep it there any longer than necessary. Right? How do I know if I polymerized my BD and what are the consequences? Don't get too technical now. I really am an "old fart". Tom
__________________
Speaking of "old farts" when I moved to a new residence a few years ago, I kept driving from work to my OLD house. I sure hope Don will be OK after he finishes moving. We may have to send him a GPS unit to make sure he makes it to the new house (him being an old fart you know). I really am an "old fart". Tom
Yep, you're even older than me! ( and my kids say I'm older than dirt!!) That's ok tho, I earned every one of these gray hairs the hard way!
__________________
You pretty much got it. Even a short time at 150 degrees may cause some polymerization but not enough to be problematic.
Quote:
The first sign of significant polymerization will be thickening to a syrup like consistency, this could be accompanied by some color change. In later stages you could see some floating or percipitated gelatinous material but by then you would be aware that somthing is dreadfully wrong.
Consequences would be plugging of small passages, injectors, and increased pressure on the fuel pump possibly pump failure.
__________________
On our 20,000 mi trip around the US and Canada last year in our 87 f250 we mostly ran svo, but used #1 and 2 with bio-d in varying blends as starting fuel. I did run several tanks of bio-d in my heated svo side without any apparent trouble.
Does bio-d polymerise (sp?) more readily than svo?
Mike
