THe FORD letters on the hood and model/trim id plates above the "dent" id this as a 1978 or 1979 model,not a 1975 so while it should have had a 351/400M engine its NOT a highboy.. it looks higher than most,so someone added a lift kit later! at the angle of the photo,had this truck been a highboy,with its divorce mounted transfer case,you should be able to see the t-case hanging down in the space visible between the back edge of the front pass side tire,and the front edge of the rear drivers side tire..... Again,its a nice truck,and while it sits at about the same height as a highboy,it isnt!
Headlight/grille combo shows it's actually a 79. The 78 had round headlamps and in 80 they went to the plastic grille that angled out from the headlamps and turn signals.
Just base models had round headlights in 78. The rest had rectangular same as the 79s. 1980 was a completely different body style.
__________________ Russ 1976 F250 2wd Explorer - In the family since the Bi-Centennial "Are you going to bark all day, little doggy, or are you going to bite?" - Mr. Blonde "Now, don't get me wrong, I'm all for conversation, but maybe you could just shut up for a moment?" - Korben Dallas iustus morsus mihi
No... Just seeing the "General" was enough to make me hurl... HOW DARE HE! discrace the general like that!
AT THE VERY LEAST use a freakin dodge truck, and it better have a dang hemi in it too!
The only thing that would make me feel a little better about that truck is if was hemi powered... Big inches, and it better be charged!
__________________
Don
I like bacon.
95. f250 4X4. "stock" 5.8l mated to a zf 5speed.
37" good years and some fender trimmin.
My landing is down pat...
I used to do it on my dirt track car all the time...
Then that got jacked about the same time i stopped caring if my paint got scratched on the truck, so i started doin it on the truck...
I can only go passenger to driver side though...
__________________
Don
I like bacon.
Yea thats the way i used to do it too. But then i realized why the heck do i want to slide from driver to passenger side, im the only one that drives my truck, so i re lernt myself on how to do it, and now i cant do it the other way.
UT: Do you have a problem denting hoods when you do it?
You kinda a big boy...
__________________
Don
I like bacon.
lol....
Yea, it hurts like a sum beach if you dont get enough height, i usually catch it right on the button on my hip.... Bad place to put a button or a rivet or what ever the heck it is.
__________________
Don
I like bacon.
now when i did it instead of leavin an azz print on th hood i i left in in the dirt hahahaha i still dont think my tail bone has completely healed from that one
__________________
PROJECT and DD---95 ford f150 4x4, 300 INLINE SIX!, 5speed, SAS, 4" lift, 35x13.50 ground hawgs (sooner or later)
PARKED---91 ford f150 lariat, 302 v8, auto, 2wd, rust
PARKED---92 ford f150 xl ext. cab short bed, dual tanks, 302 v8, auto, 2wd, LOUD!, very little rust!
