Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 08-21-2008, 12:44 PM
commandersander's Avatar
commandersander commandersander is offline
2003 Ford F-150
commandersander is starting off with a positive reputation.
220, 221...whatever it takes!
Seriously....I need the real answer....
Over and over, I have received conflicting info on which lower pulley is safe for me...
Some say 4lb, others say 6....because the HD has a different pulley than the L on the SC....a 6lb for the L is the same as a 4 on the HD....
Don't know 'bout yall....but I think the extra 2psi would suck-bad if that is not right.....
For those that need a refresh.....
1997 F-150 4x4 3-door 4.6 Vortech SC turned
1997 F-150 4x4 3-door with a 2003 HD 5.4 SC Transplant in front of a WAAAAY expensive Art Carr 4R100. Cluster and computer are 03 Lightning. C&L uppers, Accufab single blade, Lightning MA, SCT2 Flash
So....whattadillio?
  #2 (permalink)
Old 08-24-2008, 05:55 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Founder ... Stay Tuned
Garage is empty, add now
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
A 6lb pulley in the Harley over stock is okay. The stock tune is pretty damn good up to that point, anything after that... no dice. I've tuned plenty of them (HD's) at 6lbs over stock and while there is extra power to be picked up with tuning in stock form the A/F ratios are pretty good, and sold a ton of 6lb pulleys to Harley guys who left the tuning stock. You're only getting about 4lbs actual boost over stock with it because of the upper pulley, and even the Lightning can be run without an aftermarket tune at with 4lbs over.
__________________
The best is yet to come....
  #3 (permalink)
Old 08-24-2008, 07:26 PM
2003 Ford F-150
I have an SCT2, so throwin code at it should be a non factor...
Thanks for confirming about the boost difference. Keep in mind, I'm running an L computer, but I think it is going to see it as 4?
Tags
220, 221, takes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
