Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 08-20-2008, 01:36 PM
John_deere_kid's Avatar
John_deere_kid John_deere_kid is offline
1993 Ford F-150
John_deere_kid is starting off with a positive reputation.
1994 Cam
I got a 1993 Flareside that I am putting a 351w in, and I was wondering what the cam number for the lightning cam is. Could anyone help me out?
__________________
Currently Fordless
The Company Truck
2008 F350 4x4
Ext. Cab, 9ft Knaphede Service bed, 3203 Auto Crane, V10 Automatic. Lives in the oil fields of Northwest PA
  #2 (permalink)
Old 08-20-2008, 02:10 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Do you mean the Ford part number or the cam profile?
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #3 (permalink)
Old 08-21-2008, 07:36 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
See the table below. But if you are going through the trouble of changing the cam put something better than stock in it, these motors can use as much help breathing as they can get. I have the Crane 444232 in my 5.8, it works very well and is compatable with both SD and mass air.
Click the image to open in full size.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1990 2.3L 5-sp Ranger 3.08, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
  #4 (permalink)
Old 08-21-2008, 03:22 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Don't waste your time with a GEN 1 cam swap. If you're block has the correct casting number, then a roller cam swap would be a better/inexpensive option.
First off, what have you done, or plan on doing,to your motor?
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #5 (permalink)
Old 08-22-2008, 07:50 AM
1993 Ford F-150
I haven't done anything to the motor yet other than cone air filters. I dont know what all I can do being that it is SD. I dont plan on boring or stroking, just a senior in highschool here, not making a whole lot of money since they won't give me more than 25 hours a week. I was kinda thinking about some longtube headers, but then I dont know where to run the exhaust down the passenger side since there isn't much room.
__________________
Currently Fordless
The Company Truck
2008 F350 4x4
  #6 (permalink)
Old 08-23-2008, 10:54 PM
Blurry94's Avatar
1994 Ford Lightning
The driver side mid-pipe can cross over just under the tailshaft of the transmission. There are several options at that point; go with the GEN 2 style system or dump it past the rear tires or straight out the back.
You can do quite a bit with speed density and an adjustable fuel pressure regulator before any tuning is needed. Also, you can advance the base timing a few degrees too and that'll be a noticeable difference. You'll need to remove the spout connector to do this effectively and higher octane levels will allow the most timing advance.
What type of transmission do you have?
__________________
Matt C.
  #7 (permalink)
Old 08-24-2008, 09:01 PM
1993 Ford F-150
I have the e4od transmission. Spout connector?
__________________
Currently Fordless
The Company Truck
2008 F350 4x4
  #8 (permalink)
Old 08-25-2008, 09:35 PM
Blurry94's Avatar
1994 Ford Lightning
The spout connector is located just below the cruise control servo; it has two wires going into a connector with a molded plastic jumper connected to it. Remove it before advancing the base timing. You should notice a difference if you add 2-3 degrees.
There are shift kits available for your E4OD which will firm and quicken up your shifts and minimize wear during shift transmissions. These kits are fairly inexpensive and relatively easy to install.
__________________
Matt C.
  #9 (permalink)
Old 08-26-2008, 05:38 AM
1993 Ford F-150
Okay, thanks for the advice. Which brand do you reccomend?
__________________
Currently Fordless
The Company Truck
2008 F350 4x4
Tags
1993, 1993flareside, 1994, 351w, 58, cam, connector, f150, ford, lightning, roller, spout, swap, tuned
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
