Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-19-2008, 10:41 PM
Damon_Tirerack's Avatar
Damon_Tirerack Damon_Tirerack is offline
PLATINUM SPONSOR
Damon_Tirerack is starting off with a positive reputation.
My first major detail - My True Blue 04 F-150
For years I have wanted to get myself into a good polishing setup but was a bit intimidated by all the machines, pads, and compounds out there. Until this point I have been doing everything by hand. We have an XC-90 and a full size F-150 so doing it by hand just got to be too much work - with only some of the possible results for the effort. I'm getting to be a bit of a minimalist so I wasn't in the mood to go experimenting with products until I found out what worked. The pros may like to experiment, but some of us shade tree detailers want a system we know works well without ending up with dozens of bottles of product that won't get used. I also wanted a polisher that a novice would not burn the paint with and that wasn't a throwaway if a $.50 part gets broken. Being short and having a full size truck on blocks as well, I needed something I could reach up the hood with, too and able to control it with one hand. After seeing the results of the Gloss-It Cyclo paint correction system on a few of my other forums I called Rich at Gloss-It. I told him my concerns and he recommended the same system for my cars. What he sent me was just what I wanted.
After my first time warming up on my silver Volvo which was just detailed a year ago I figured I was ready to try a navy blue truck. Getting used to the machine was easy. By the end of my truck I was feeling quite used to it. I LOVE the build quality of the Cyclo. The Volvo was basically a quick Evolution Polish with green and then Gloss with white pads.
Next onto my Ford. She's a big 'un, so I had to wait until I had quite a bit of time blocked off to do it. Total washing, claying, rewashing, drying, taping, and shining was probably 10 hours - and that's ignoring the wheels and interior! >>
The truck is an 04 with 16k miles, but the guy I bought it from took great care of it. After claying I was pleased with the shape of the paint. Minor drying scratches was all I had to deal with.
The worst of the defects were on the tailgate. It's a truck - I use it like one once in awhile.....
Note to self: Never close the tailgate with muddy work gloves on again.....
__________________
Representing The Tire Rack
877-522-8473 Ext. 643
574-287-2345 Ext. 643
574-236-7707 fax
**Don't forget to add my name to online orders when checking out!**
  #2 (permalink)
Old 08-19-2008, 10:43 PM
PLATINUM SPONSOR
These are what scared me the most. I opened the tailgate onto gravel sitting on the bumper. The sound of stone cutting into clearcoat is pretty unforgettable....
Minor scratches from pulling pea gravel out of the truck:
And only one waterblade scratch up in front of the passenger window:
To start out I was pretty chicken being such a greenhorn. Remember, this is only the second time I have EVER picked up a polisher, and the FIRST dark vehicle I have ever done. I taped some areas off, but next time I'll tape more. MUCH more....I spent way too much time at the backside cleaning up spots I hit with the polisher. Had I used a machine with one large pad it would have been ugly! The front quarters on the F-150 are pretty small so I figured they would be good test panels. I taped this one off and did the left side using yellow pads and Evolution cut.
Results were good but pretty slow to get. I'm not sure how hard Ford clear is, but it seems pretty hard to me!
I was still pretty chicken so I kept using the yellow pad/Evolution Cut combo for the rest of this side. I wanted to go more aggressive but figured I would continue to cut my teeth with the unit. It was definitely working....
__________________
574-236-7707 fax
  #3 (permalink)
Old 08-19-2008, 10:44 PM
PLATINUM SPONSOR
When I finally worked my way down the passenger side and got to the tailgate I knew I had to get the bigger guns out. After consulting with Rich he told me to go full monty with Orange pads and Extreme Cut, which is what I did. After doing the tailgate I realized I could have saved about an hour of polishing on the side had I just had the guts to try. Extreme Cut on an orange pad worked wonderful. It has just the right amount of cutting ability to see results while working, but not too fast to let things get out of hand. The top scratches were now completely gone after hardly any time at all:
The bottom gouges needed more work so I hit them with the Cyclo the best I could but had a hard time getting over the hump at the base:
I decided to get in there with my fingers and hand rub out that final half inch until it was 90% gone. Given the depth (almost through) it was the best I could do. Results were much better.
From this:
To this:
I can't believe that someone with NO experience using a polisher could do this!
Remember the waterblade scratch in front of the window? Buh-bye....
After the tailgate I was feeling pretty confident about the rest of the truck so it was off to the driver side. I don’t have too many picks from this side because it was dark and a buddy had my halogen spots.
Still some swirls:
After cutting this side with the light I did have I could tell it was was shining pretty good.
I ended up finishing the rest of the truck with Extreme Cut on an orange pad and then RE-doing the entire truck with a green pad and Evolution Polish before hand wipe with Gloss Activator and then Gloss Finish with the white pads. Finally, I wiped the dew off the next morning and applied a coat of Gloss Enhancer. The final step was a quick coat of T.V.R. and the vinyl and grabbed the camera:
Hard to tell where the truck stops and the sky starts:
The sun sets on a finished project…..
I can’t begin to explain how impressed with these products I am, especially the more I use them. After just my second car I am ready to tackle more. It’s nice to know that 4 pad densities and 4 compounds are all I need to get this kind of shine. The Cyclo was definitely the right machine. And it’s also nice to know if I have questions he’s available to answer them. And if you think you will damage your paint, you won't unless you REALLY try to. What are you afraid of - Give Rich a call.
Thanks again Rich, thumbs WAY up for your products.
If interested in the same setup for yourself, here’s the link to the products:
Store - Gloss It - An Evolution in Appearance Products - Car care, detailing, car wax, detailing spray, purchase online
__________________
574-236-7707 fax
  #4 (permalink)
Old 08-20-2008, 12:02 AM
Svets96's Avatar
Svets96 Svets96 is offline
Svets96 is starting off with a positive reputation.
Wow good job man. Your truck looks incredible! That true blue is a nice color it looks real good when its clean.
  #5 (permalink)
Old 08-20-2008, 02:04 AM
sealboy84's Avatar
sealboy84 sealboy84 is offline
sealboy84 is starting off with a positive reputation.
Beautiful job.... do you make housecalls?
__________________
'99 F250 PSD LONG BOX X-CAB 4X4
Foil Delete-6637-cold AC Mod-Garmin Navs-Wicked Wheel
Jay
JOIN NEW MEXICO CHAPTER HERE!
  #6 (permalink)
Old 08-22-2008, 12:06 AM
Svets96's Avatar
Dang everytime i'm in the detail section I have to click on this post and say wow this truck looks really good.
  #7 (permalink)
Old 08-26-2008, 03:29 PM
PLATINUM SPONSOR
Thanks for the compliments.
Again, If anyone is interested in the same kit I bought, call Rich at Gloss-It. This kit has everything you need to do the same job. And Rich was great for answering questions. I had no experience prior to this, and he makes the process "idiot-proof".
Tell him I sent you.....
__________________
574-236-7707 fax
  #8 (permalink)
Old 12-09-2008, 11:24 PM
Flying_Dutchman's Avatar
Flying_Dutchman Flying_Dutchman is offline
Flying_Dutchman is gaining momentum as a positive member of FTE. Flying_Dutchman is gaining momentum as a positive member of FTE.
Ive been nervous about trying this myself, but after seeing your results I think I should try and tackle this as soon as I get a sunny day.
  #9 (permalink)
Old 12-14-2008, 04:03 PM
papajoemrt's Avatar
papajoemrt papajoemrt is offline
papajoemrt is starting off with a positive reputation.
That looks remarkable man. I did this on my 02' F150 for a capstone project for school, I go the same results, but living on a dirt road they don't last too long but oh does it feel great when you finish it up like that am I right?
  #10 (permalink)
Old 01-28-2009, 01:04 PM
lakeforkfisherman's Avatar
lakeforkfisherman lakeforkfisherman is offline
lakeforkfisherman is starting off with a positive reputation.
Nice job on the detail. Next time you are in the Dallas area, with your detail equipment, let me know. Oh- by the way, my truck is black!
  #11 (permalink)
Old 01-28-2009, 01:32 PM
PLATINUM SPONSOR
Quote:
Sorry, Indiana is a bit of a haul to Texas. Give Brian at Detailwerkz a call. He's mobile and in the Dallas area and uses the same equipment and compounds - and he's WAYYY better than I am! Tell him I sent you... frisco mobile car detail company, frisco detail company, plano mobile car wash, plano mobile detail company, mobile detail company in dallas, mobile detail comany in southlake, southlake mobile detail company, coppel mobile detail company, lewisville
__________________
574-236-7707 fax
  #12 (permalink)
Old 01-28-2009, 06:16 PM
2tonsoffordfun's Avatar
2tonsoffordfun 2tonsoffordfun is offline
2tonsoffordfun is starting off with a positive reputation.
wow, i own and operate a detail shop and im impressed with what you did....amazing considering you're a first timer....what a beautiful color. Oh and if you work at tirerack tell william dalton i said hi....that is if you work with him....i bought some nitto terra grapplers through him a few months back and they are working out great.
  #13 (permalink)
Old 02-15-2009, 02:42 PM
RonC80's Avatar
RonC80 RonC80 is offline
RonC80 is starting off with a positive reputation.
What a really great detail on the blue truck
  #14 (permalink)
Old 02-23-2009, 01:33 AM
F250racer's Avatar
F250racer F250racer is online now
F250racer is starting off with a positive reputation.
That truck looks absolutely amazing! Great job. I must say it's pretty satisfying to stand back and look at your rig after a good detail job.
__________________
Colin
1959 F-250 Longbed 292 V8. Four on the floor manual. 2wd Styleside
"The truck's a Ford and the tractor's green"
  #15 (permalink)
Old 03-18-2009, 06:49 PM
Quick444's Avatar
Quick444 Quick444 is offline
Went Big, Got Sent Home.
Quick444 has a good reputation on FTE. Quick444 has a good reputation on FTE.
Very impressive! That truck looks great. Hard to believe you had never done that before. This thread could give people the confidence to jump and try it.
__________________
-Alex- 01 F250 PSD, 4x4, CC, SB, AUTO.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
