Steering locks up when turning - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-19-2008, 09:39 AM
fixxxer-upper's Avatar
fixxxer-upper fixxxer-upper is offline
FTE Fan
fixxxer-upper has a good reputation on FTE.fixxxer-upper has a good reputation on FTE.fixxxer-upper has a good reputation on FTE.
'04 F250 CC 6.0 4x4 74K Miles
When making right turns and returning the steering wheel back to center, the steering locks up and sticks. If I wiggle the wheel slightly to the right and back to the left, the lock up goes away allowing me to return to center.
I just replaced upper and lower ball joints because they were shot. Took the truck for a test drive last night and the steering problem still exists.
Thanks in advance!
Old 08-19-2008, 09:48 AM
pile_53574 pile_53574 is offline
pile_53574 is starting off with a positive reputation.
If your truck is 4wd, try greasing your front u-joints, the only greasable joints in the whole truck(why)?? I had same prob, greased joints and it helped, but I think I let them get to far as it still does it once in a while
Old 08-19-2008, 02:41 PM
FTE Fan
Just picked the truck up from dealer diagnostics. They said the steering gear box was bad. Of course not under any warranty. Dealer wants $655 to replace it. $179 from AutoZone and me under the truck again tonight will take care of it. Thanks for the reply.
What else should I be expecting to fail before 80K miles?
Old 08-19-2008, 03:17 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
it doesn't have a steering damper does it? I wouldn't necessarily expect anything to be failing. Sounds odd for the steering box, but have heard of it.
Old 08-19-2008, 09:05 PM
WestxSRT10's Avatar
WestxSRT10 WestxSRT10 is offline
WestxSRT10 is starting off with a positive reputation.
Have you owned the truck sence it was new? If not someone could have over tighten the steering box adjuster nut, which will cause the gears to ware out prematurely.
2006 F250 Steering problem shadylemon1 Brakes, Steering, Suspension, Tires, & Wheels 5 11-23-2014 01:42 PM
Steering Play - Is this adjustbale? SoCalAngler 1987 - 1996 F150 & Larger F-Series Trucks 3 11-21-2014 05:48 PM
ignition switch key linkage broken softshoes Ranger & B-Series 18 07-03-2013 10:55 AM
steering wheel locks up Y2K1TON 1999 to 2016 Super Duty 11 12-20-2010 03:59 PM
F150 steering doesn't return to center matt hesley 1987 - 1996 F150 & Larger F-Series Trucks 13 01-13-2004 12:57 PM
Tags
06, 2003, 2004, duty, f250, ford, freezes, lock, locks, steering, super, truck, turni, turning, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
