Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-19-2008, 01:39 AM
blkbeast blkbeast is offline
Garage is empty, add now
blkbeast is starting off with a positive reputation.
Good Batch
Finally got a good 25gal batch to turn out. Filtered out the magnesol down to 1micron absolute and it looks real good. It just takes forever to filter. For lack of a better set up at the moment, I hung the bag filters over 5gal buckets. Used my siphon pump to pump from my processor into the filter, let the filter drain down some and pumped more into it. Took most of Thursday to get it filtered though all 3 stages (25m, 5m, 1m). I'm going to make sealed filter housings out of pvc, and am considering using a 1/6hp utility/sump pump to pump the fuel through the housings. The pump/impeller have large clearances and I don't think it would shear the magnesol enough to make much of a difference. At the moment I'm using a 1/4hp sump pump to transfer my oil without any problems. Anyone forsee any problems with what I'm considering?
  #2 (permalink)
Old 08-19-2008, 07:39 AM
Gun-Driver's Avatar
Gun-Driver Gun-Driver is offline
Gun-Driver is starting off with a positive reputation.
I let it settle over night then pump off the top being careful not to suck up any magnesol in the bottom. You dont have to worry about the shear effect of the pump because its all settled to the bottom. I filter through 1 micron bags right off the bat and can do several batches before the bags clog up.
  #3 (permalink)
Old 08-19-2008, 11:06 AM
empiretc's Avatar
empiretc empiretc is offline
empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.empiretc has a great reputation on FTE.
that is exactly what i do!
__________________
If the lunch meat called spam became the catchword for a depersonalized email message, then social networking should be known as soylent green!
Please, do not text & drive: http://www.youtube.com/watch?v=gRwfq7Igvxc
-David
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
