Could we be seeing the Scorpion sooner than expected?
This contradicts allot of the other information floating around, but I was reading a recent issue of Automotive World (usually provides reputable information) that Job 1 of the Scorpion diesel is now just 12 months away. They reported that Job 1 is now slated for August of '09 at CEP (Chihuahua Engine Plant)...
__________________
'04 F-250 Harley-Davidson 6.0L CC SB
Why would Ford do that if there are no significant problems with the 6.4? And doesn't their contract with Navistar run through 2011? They'd have to pay Navistar off or get tangled up in another lawsuit.
__________________
2003 F250 CC LB 4x4, 6.0 with auto
I believe the contract runs thru 2012, but at any rate there is a lot of bad blood between the two companies and it is obvious that Ford wants out at pretty much any cost. Ford must be seeing some potential benefit somewhere out of a early separation. It may not be as obvious, but I am sure Navistar would not mind getting out either.
One benefit for the SD trucks and its potential buyers will be the eventual offering of 2 diesel engines rather than 1...
__________________
The real question here is will the 6.4 be compliant with the 2010 diesel regs? I read an article where International was saying Ford has not asked them to make the 6.4L 2010 compliant. Makes me think that the 6.7 Liter engine will be out for the 2010 year truck but the 2011 model. The same thing they did with the 08's. Diesel regs changed for 2007, but we did not see a new model and engine till 2008.
I'm really happy with my 6.4 and could care less what Ford brings out in the near future. The 6.4 was designed on the legacy of similar International diesel engines some of which were plagued with problems that have been corrected in the 6.4
Who knows what problems will befall the new Ford Scorpion engine. The use of Aluminum heads is something that could pose a problem down the road, especially in the event of an overheat condition.
__________________
2008 F250 6.4 4X4 Lariat 3.73 SRW SC
Ford 6.4 The Politically Correct Diesel
The 4.4L should be expected for release late year 2009 (2010MY). It is beginning the process of emissions certification as of just a few days ago; so release is approx. a year away on it.
The 6.7 isn't quite ready for certification; it will likely be a few more months before the process is started. Take my guess for what its worth; but I would speculate January 1st 2010.
I can't till you where I've seen this info, but I think the new engines will use urea injection systems to meet the new emissions. By doing this I have read that possibly the egr valve will be eleminated and may not have to use a regin system either. By doing this (the urea injection) there is supposed to be a noticable mpg increase.
Also a completely new 6 speed tranny (it would be nice if they were "paddle" shifters) is supposed to be released soon.
__________________
2006 6.0l Lariat 4wd, CC, LWB, Auto, Tow Command, 18 inch wheel option, 10,000 GVWR
The new Ford diesels will be using DEF (urea) as part of the emissions system, but this will not eliminate the EGR. EGR will still need to be there to comply with emissions, but less exhaust gases will have to be recirculated. This should help greatly reduce EGR problems. The engines will still be equipped with a DPF, so regenerations will still be necessary. Although it is likely that only passive regenerations will be needed. I hope...
The new 6 speed auto will be the 6R140 and should be a great trans...
__________________
You are absolutely right. Less EGR means less soot and better fuel economy. Certain duty cycles will likely see active regens where others may never see one. Our OTR tractors will never see an active regen.
It wouldnt suprize me... If they Kept changen every-year till they got back to 7.3Liter. BTW... I think after the contract runs out they will invest in Cummings for there D's JMO
cummins...no g, and no that will not happen.
__________________
2005 Cummins 4x4. IS GONE!!
Previous truck:04 F-250 PS 4x4. miss it badly
Ryan
The closure of the Indianapolis engineplant in July 2009 must speed up the introduction of the Scorpion as Ford must have a replacement for the late 6.4-litre.
"In the important North American market, the series production of five new high volume SinterCast-CGI V- diesel
engines remains on schedule for start of production during early-2009."
