Go Back   Ford Truck Enthusiasts Forums > Diesel > 2011 6.7L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2011 6.7L Ford Diesel Discuss the upcoming Ford Powerstroke 6.7L diesel engine
Is F-150 Still King?
  #16 (permalink)
Old 03-01-2009, 07:43 PM
02puffer's Avatar
02puffer 02puffer is offline
02puffer is starting off with a positive reputation.
Urea will be the big thing to do me thinks. Easier and cheaper than EGR (from a warranty repair cost anyway) and the only argument against it is a moot point: "Oh no I don't want to have to remember refill some tank!!" like BMW, the dealer will refill with every service done.
  #17 (permalink)
Old 03-01-2009, 09:15 PM
origcharger origcharger is offline
origcharger is gaining momentum as a positive member of FTE. origcharger is gaining momentum as a positive member of FTE.
Quote:
You are still going to have EGR and it would have to be a pretty good sized urea tank to last a Ford Super Duty from one service to the next.
__________________
2004 E-450 6.0 139,000 miles
7,500 mile, 15 quart oil changes, 5W-40 Rotella.
UOAs consist of checking for metal on drain plug magnet. All stock, no mods. Dyed fuel with no additives. Never been reflashed.
Total parts replaced;
one EGR valve.
  #18 (permalink)
Old 03-02-2009, 08:19 AM
02puffer's Avatar
Quote:
Very true, theres alot of space inder the cab/bed to shoehorn a tank in but it will be in Fords hands as to where it goes and getting it plumed. If they do use that system, getting an owner back for service is as easy as an idiot light on the dash.
  #19 (permalink)
Old 03-02-2009, 08:35 AM
Well, I would bet there is a larger percentage of BMW owners who willingly take their cars back to the dealer for servicing than there would be Ford Super Duty owners.
I also can't imagine many Super Duty operators who would gladly interupt a job/vacation to schedule a dealer service because their low urea idiot light came on. And a cars fuel/urea consumption rate is likely more predictable as fully loaded/trailer towing is not in the equation.
__________________
one EGR valve.
  #20 (permalink)
Old 03-08-2009, 01:41 AM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is starting off with a positive reputation.
Wonder if urea freezes?
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4 moose lites
Mobil-1 Turbo diesel truck oil
fuel filters every 10,000 miles
AstroStart auto start
98 gal Transfer flow tank
Rhino liner on the rockers
Wabasto-Blue heat
MBRP turbo back duels w/ no CAT
  #21 (permalink)
Old 03-08-2009, 01:53 AM
PowerStrokeHD PowerStrokeHD is offline
PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE. PowerStrokeHD has a great reputation on FTE.
Quote:
It is not supposed to freeze, but it does get slushy...
__________________
'04 F-250 Harley-Davidson 6.0L CC SB
  #22 (permalink)
Old 03-08-2009, 03:56 AM
rollerstud98 rollerstud98 is offline
rollerstud98 is starting off with a positive reputation.
They should just run some coolant lines through the tank, keep it warm
  #23 (permalink)
Old 03-09-2009, 12:05 AM
pstrang pstrang is offline
pstrang is starting off with a positive reputation.
I was under the impression that UREA reduces NOx emissions which is the same function as the EGR. I hope there isn't both in the new engine. UREA should replace the EGR.
But as for the DPF, I believe we're stuck with them.
__________________
2005-6L/PSD F-250 Lariat CC/SB/4x4:
- MBRP 4" turbo back, CCV4500, coolant bypass filter, oil bypass filter, X-monitor, Fluidampr, fuel x-over line, intake elbow, EGR cooler delete w/ welded uppipe, wrapped headers and turbo hot-side.
  #24 (permalink)
Old 03-09-2009, 12:15 AM
Quote:
They are going to run some form of onboard heating for the urea tanks, but im not sure exactly what form. I know the EPA is allowing a period of non-compliance to allow the urea to thaw out...
It will be a combination of both EGR and SCR (urea) that will be used to meet emissions...
__________________
  #25 (permalink)
Old 03-09-2009, 05:45 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
Well, not to stir the SCR pot, but here's a story that provides a little more in depth look at the Urea strategy. Granted it's not a Ford, but the technology isn't necessarily going to be specific to one manufacturer either.
Chrysler Diesel Exhaust Fluid System Previews NOx Reduction Solutions for 2010 - PickupTrucks.com News
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #26 (permalink)
Old 03-09-2009, 06:29 PM
Quote:
Both! Lose the EGR and go with SCR (urea). We don't want both.
__________________
  #27 (permalink)
Old 03-09-2009, 08:40 PM
We don't have a choice.
__________________
one EGR valve.
  #28 (permalink)
Old 06-15-2009, 10:40 PM
Silentst2000 Silentst2000 is offline
Silentst2000 is starting off with a positive reputation.
nevermind delete this
Tags
2010 , 6r140 , diesel , f250 , scorpion
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
