1999 F350 7.3 Low RPM-Miss-Shutter-Please Help!! - Ford Truck Enthusiasts Forums
Old 08-18-2008, 06:18 PM
pullnit pullnit is offline
pullnit is starting off with a positive reputation.
Hi all
I have a 1999 7.3 F350 with 134,000 miles on it.I pull a 15k 5er. While pulling home today it felt as if I had a unbalanced wheel hop at 1300-1500 RPM. When I pulled off at the truck stop the idle is very shakey. At take-off there is a low RPM shutter/miss untill RPM is above 1500. I changed the fuel filter it was full of crap but didnt remedy the problem. It also makes a sqwheel type ChIRP sound on shut-down . So far I changed the oil-Ran 2 tanks of fuel with dieselclean and changed the CPS from gray-black. What should I do next??? Thanks John
<!-- / message -->
2011 Super Duty tranny problems Front Runner 6.2L V8 568 11-07-2015 03:11 AM
Fuel Heater Element- 7.3L ? ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 23 03-04-2015 11:59 PM
INJECTOR SHIMMING timmyboy76 1999 - 2003 7.3L Power Stroke Diesel 6 02-11-2015 09:32 PM
2012 SD Order Guide kmonty2 6.2L V8 8 08-01-2011 06:31 PM
Anyone heard of tranny problems in the 2011? Krewat 6.7L Power Stroke Diesel 10 08-25-2010 08:50 AM
Tags
1999, 73, 73l, 99, f150, f250, ford, low, lower, miss, misses, powerstroke, rpm, rpms, shutter, shuttering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
