1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
ORU 1/2" of lift via boomerang shackes
Old 08-18-2008, 03:06 PM
semcderm's Avatar
semcderm
semcderm is offline
Anyone out there used these? seems like a good way to get 1/2 inch of lift to fine tune a trucks front to back rake, any issues ? or other thoughts ? just trying to consider all lift options out there, thanks in advance
Old 08-18-2008, 03:09 PM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
do you have a link to them??
Old 08-18-2008, 03:31 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Old 08-19-2008, 12:23 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
I don't like them, better off to go with a longer straight shackle that has the cross brace welded in.
Old 08-19-2008, 10:28 PM
RACERX7775's Avatar
RACERX7775
quote right from the site....sems like a good idea..
When using super soft springs in the front of the Super Dutys & Excursion, the shackle cross bar has a tendency to hit the frame on compression. These new shackles are made of 3/8" plate so they need no cross bar. These shackles are 1" longer and shaped like a boomerang so they do not hit the body mount.
Old 08-20-2008, 02:47 AM
cartmanea's Avatar
cartmanea
Without the cross bar you'll get more side-to-side movement.
dunnerjeff
01-21-2015 06:54 AM
SenderoSFII
18
08-09-2014 04:25 AM
biggyfan1
11-01-2013 12:18 AM
housedad
09-14-2013 02:53 PM
NewEnglander
1978 - 1996 Big Bronco
89
09-08-2013 07:16 PM
Quick Reply: ORU 1/2" of lift via boomerang shackes
