Tailight / Brakelight / Cruise Problem
I know this isn't a diesel specific problem but here goes...
I turn on the running lights and the brake lights come on. Checked the bulbs and removed all and still the high mount brake light comes on... Disconnect the brake switch and still... The turn signal switch will stop the problem but it would be difficult to drive that way. I did change the ts switch (used - no history) and no difference.
Any ideas? I did change the headlight doors/trim this weekend but what could I have done? Just unplug and re-plug wires. And there is no brake light circuit up front that I could've shorted. Out and back in with the batts.
I am stumped.
I am stumped.
These may help,sorry they are a little big...thanks to TJ for these
Webshots-Grand Wiring Dia1
Webshots-Grand Wiring Dia2
Remove both outer (bedside) stop/tail/turn bulbs, and turn on the parking lights again. If the center stop light no longer lights up, there's an internal short in one of those bulbs (the two filaments touching, for example). Try putting each one back in and check to see when the problem comes back.
