P0308 code - Ford Truck Enthusiasts Forums
P0308 code
Old 08-17-2008, 06:53 PM
jwillyf150's Avatar
jwillyf150 jwillyf150 is offline
jwillyf150 is starting off with a positive reputation.
P0308 code
Just got a new code p0308 (cylider 8 misfire); anybody know where the coil pack I need to replace is located on the 5.4 L or any other ideas would be appreciated. I've got 69K miles on my 06 fx4 so I guess it's getting close to time to replace plugs. Just want to know where coil pack 8 is located for now tho. Thanks
Old 08-17-2008, 07:24 PM
Capbyrd Capbyrd is offline
Capbyrd is starting off with a positive reputation.
it wont be a coil pack. just a coil and it is sitting on top of cylinder number 8. the spark plug connects directly to the coil.
Old 08-17-2008, 08:27 PM
jwillyf150's Avatar
Quote:
where is number 8 located ? So you are saying I need to replace a coil/sparkplug?
Old 08-17-2008, 08:38 PM
Lead Head Lead Head is online now
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
I do not have nor have not worked on a 5.4, but the way I understand is that the 5.4 has a COP system or Coil Over Plug. So there is one coil for each plug. 8th cylinder should be drivers side rear cylinder.
It could be from a bad coil, sparkplug or a sticky injector. Most likely the plug or coil though. Remember, start with the cheap stuff first!
Old 08-18-2008, 08:36 AM
jwillyf150's Avatar
Found a small leak in my exhaust, could this cause that code to come up? My truck runs fine until I go to pass or get on the interstate then it kinda stutters but eventually goes on. Bad gas maybe??? I have been running 89 & 93 octane but just recently switched to 87 cause of prices. No problems when I was running the higher octane so that could be the problem I guess?
Old 08-18-2008, 08:53 AM
Quote:
Originally Posted by OBD-Codes.com
P0308 Code - Cylinder #8 Misfire
Technical Description
Cylinder #8 Misfire Detected
What does that mean?
A P0308 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #8.
Symptoms
Symptoms may include:
the engine may be harder to start
the engine may stumble / stumble, and/or hesitate
other symptoms may also be present
Causes
A code P0308 may mean that one or more of the following has happened:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
maybe this will help get you started.
have you looked to see where the exhaust leak is? if so, is it pre or post cat?
Old 08-18-2008, 08:56 AM
jwillyf150's Avatar
post cat right where the exhaust pipe is directly in the center of the truck going from drivers to passenger side. I'll add some injector cleaner and see if that works first.
Old 08-18-2008, 09:10 AM
something else you can try is moving the coil from cylinder 8 to cylinder 7. if the code comes back on cylinder 8, then the coil is not the problem. if it comes back on cylinder 7, then the coil is bad.
Old 08-18-2008, 10:45 AM
jwillyf150's Avatar
Is the #8 located on drivers side next to the firewall?
Old 08-18-2008, 10:51 AM
yes that should be number 8
Old 08-18-2008, 09:10 PM
FordTechnician FordTechnician is offline
FordTechnician is starting off with a positive reputation.
#8 Cyl. is on the drivers side all the way in the rear. If you are going to replace the sparkplug, be very carefull, it could be stuck or even break.
If you are replacing the plug, loosen it first 1/8th turn and spray some penetrating oil in the valley and let it sit for about 15- 20 min. then rock the plug back and forth till it is out. Good luck.
2006 F-150 5.4 P0053 Stevenmed 2004 - 2008 F150 4 03-11-2016 11:28 AM
P0308 Cylinder 8 Misfire Detected 02GrayPowerStroke 1997 - 2003 F150 5 07-13-2015 06:36 PM
2001 F150 Supercrew running rough tamisms Modular V8 (4.6L, 5.4L) 10 09-28-2011 08:48 PM
I hate coil packs! three balls 1997-2006 Expedition & Navigator 19 12-20-2010 02:11 AM
Error Code P0308 misfire cylinder #8 blowncobrar Modular V8 (4.6L, 5.4L) 1 10-06-2005 12:57 AM
Tags
0308, 46, 54l, code, cylinder, explorer, f150, ford, fords, misfire, obd, p0308, po, reset, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
