Front clip mounting
on
Yup that is pretty much all that holds the front clip on...... the U shaped rad support has the two bolts in it and everything else kind of hangs off it....then the 8 or so bolts to the cab at the back......... mine was real squeaky as well but it was the inner fenders rubbing on the frame and the front suspension........ my 53 has a Volare clip so I had to trim the fenders around the upper A arms and the frame and the squeaks were gone....
I just went out and looked and there are ten bolts on each side holding the fenders and inner fenders to the cab. So that is 20 bolts at the cab + the 2 under the radiator. The cab and front clip pretty much float on the 2 swing arms at the back, 2 rubber mounts at the front cab corners, and the rubber mount at the radiator support. Thats because of all the frame flex when going over rough terrain.
No I don't have those rods. Is there a picture of those somewhere? I also have Mustang 2 IFS and new leafs in the back. I was just watching Trucks this am, they said that urethane bushings really squeak with no grease. I have no zerks on my back leafs (TCI product). I wonder if that may be a source of some squeaks. I think that they are coming from several sources including the front clip. I am going to look into those support rods too, thanks fellas.
Do yourself a favor, drop everything you are doing and give Mid Fifty a call 1 800 252 1956, ask Sy or whoever answers to mail you one of their print catalogs.
Not only does it include just about any part you might need, but it has better assembly drawings than a factory shop manual as well as a wealth of useful info. It is a must have for anone working on a 53-56! The ladies at MF are extremely knowlegable about anything 53-56 and will give you straight answers as well.
