engine id
engine id
Hi , I just purchased a new to you 56 ford f 100, it has a 6 cylinder motor in it and I want to find out what it is. The casting on the side of the block reads c3 ae 6015 ac then on the side of the block near the water pump there is a flat spot that has 3c27 on it. The intake manifold bolts on the side of the motor, the valve cover has bolts on the side of it not in the middle, I think it is a 63 223 motor, how can I be sure? thanks for any replies John
429unibody
09-08-2009 10:40 AM
gliderdad
03-27-2009 11:40 PM
jharvey3
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
01-26-2005 10:40 PM
roscoe
03-18-2004 03:28 PM
