Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 08-16-2008, 06:04 PM
landk00 landk00 is offline
landk00 is starting off with a positive reputation.
Unhappy 2002 V10 EX stalls at idle
Since having dealer work on my brakes: replaced booster and brake light switch. While at the deal the changed all the fluids. Now my EX has been intermittently stalling when stopped in drive with AC running. When it stalled the OD light was flashing. Now we have noticed that the EX is sputtering when stopped while in drive and may stall. Also, itermittently seeing the the ABS light come on. Today it stalled and now the CEL is ON. Any assistance regarding my issues would be greatly appreciated, this is the primary vehicle used by my wife and kids. Thanks in Advance!!!
  #2 (permalink)
Old 08-16-2008, 07:00 PM
cbradford's Avatar
cbradford cbradford is offline
2005 Ford Excursion
cbradford is gaining momentum as a positive member of FTE. cbradford is gaining momentum as a positive member of FTE.
You need to have the codes read then this site could help out. Just go to an Advanced Auto or AutoZone and they will read the code
__________________
Chris
05 Excursion Limited V10, 4:30(C3) Limited Slip
Mods:Front Cyro Power Slot Rotors & Hawk LTS Pads, Moog ball joints, Bilstein Shocks
01 Expy EB, 5.4, 3.55 (H9) Limited Slip
2006 27' Outback T.T. 7000lbs-loaded
  #3 (permalink)
Old 08-16-2008, 07:19 PM
dbtx dbtx is offline
dbtx is starting off with a positive reputation.
The IAC is a common problem on the V10, which will cause stalling at idle. On my truck, it was not intermittent like yours, so it may be something different.
__________________
2008 Expedition EL 4x2 with heavy duty tow package
2007 F150 XLT SCrew 4.6L Black with Chrome package
Mods: Katzkin Dark Charcoal Leather Interior, Rubber Bed Mat
2005 Excursion 4x4 Limited V10 (traded on the Expy)
Mods: Helwig Rear Sway Bar
  #4 (permalink)
Old 08-16-2008, 07:33 PM
I went to Autozone and they read the codes, telling me it is showing P02720. I am not sure what the part is or where the best place to purchase, if I can replace.
  #5 (permalink)
Old 08-17-2008, 01:19 AM
i eat hybrids's Avatar
i eat hybrids i eat hybrids is offline
i eat hybrids is gaining momentum as a positive member of FTE.
Autozone didnt tell you what the code ment?
  #6 (permalink)
Old 08-17-2008, 01:35 AM
Lost Hog Lost Hog is offline
Lost Hog is starting off with a positive reputation.
Wow...I would clean the maf sensor first. These problems mustbe related I think. is it an oiled air filter?
perhaps a vacum leak in the back firewall area.
just an Idea. Good luck bro!
  #7 (permalink)
Old 08-17-2008, 10:03 AM
rlh68050's Avatar
rlh68050 rlh68050 is offline
rlh68050 is gaining momentum as a positive member of FTE.
Quote:
P-codes are 5 digit numbers. Either P0XXX, or P1XXX. Double check what the code was.
__________________
Rob
2001 Excursion
4x4 V10
  #8 (permalink)
Old 08-17-2008, 11:51 AM
6686L 6686L is offline
6686L is starting off with a positive reputation.
. . . . my EX has been intermittently stalling when stopped in drive with AC running. When it stalled the OD light was flashing. Now we have noticed that the EX is sputtering when stopped while in drive and may stall. Also, itermittently seeing the the ABS light come on. Today it stalled and now the CEL is ON. Any assistance . . ?. . . !
Hmmm...let me think....ah ha..I GOT IT ! There is something wrong with your truck !
Seriously, you need to take a deep breath, forget what you THINK you know about auto technology...and then take a look at an EXCURSION shop manual.
What you will find, is that you dont really have a truck. You have a VERY complex system of inter-related computer devices that happens to be on wheels. Sure, we back-yard mechanics can change springs, brake rotors, and perform other simple maintainence and repair tasks that those of us who are familiar with automotive mechanical devices, can accomplish. Sure, IF you understand the uses AND LIMITATIONS of an OBD II "reader", you may be able to replace some of the computer's sensors (again, the EX is NOT a truck, it is a COMPUTER that happens to have wheels).
In my own experience here in Arizona, and in So. Calif, I have, without exception, found Ford dealer people to be VERY competent, taking care of the rare times I have brought problems to them, quickly and effectively.
I am very disappointed to read so many "posts" from guys in here, who state they have not been treated properly by Ford dealers where they live.
Maybe if you went to a Ford dealer in your area, your experience would be more like mine ?
Or perhaps there is a garage near you NOT connected with the Ford organization, but DOES have familiarity with, and the complex computer analysis, to help you out.
Bottom line - I dont see the point of trying to do much "fixin" when problems such as yours show up. You may well wind up spending a LOT of money buying parts that will not correct the problem, leaving you worse off finanically than if you simply took it to a COMPETENT garage.
  #9 (permalink)
Old 08-17-2008, 12:03 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
If the code is P0272 (0 removed), then its
P0272 Cylinder 4 Contribution/Balance Fault
Perhaps a bad coil or sparkplug?
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #10 (permalink)
Old 08-17-2008, 03:00 PM
Code actually is P0720
Sorry I typoed the code: Per Autozone the code is P0720 which shows as Output speed sensor insufficient input. Does anyone know where is can bye the part and have picture of where the part is located. I have been look and it sounds like this part is in the transmission.
  #11 (permalink)
Old 08-17-2008, 04:32 PM
rlh68050's Avatar
Output speed sensor = tail shaft of the trans. Consult the Ford service manual for the exact location and R&R instructions.
__________________
Rob
2001 Excursion
4x4 V10
  #12 (permalink)
Old 08-23-2008, 03:33 PM
The problem is getting worse, now the truck is stalling often. It seems to stall when in drive with ac running. When in reverse with my foot on the brake ac running, I then turned on the high beam of the head lights and it stalled (the OD light flashing). Able to replicate multiple times
Also, I have replaced the output speed sensor (Ford part# f81z-7m101-aa) regarding code P0720 and the problems are still there.
  #13 (permalink)
Old 08-23-2008, 10:42 PM
MadMedic20's Avatar
MadMedic20 MadMedic20 is offline
MadMedic20 is starting off with a positive reputation.
Can you put the truck in neutral and keep it running by giving it gas? If so it is most likely the IAC (Idle Air Control valve). My Ex did this one morning, would not idle at all. Had to drive it to Grand Junction Ford, putting it in neutral and reving it at stop signs. I plopped down $110 bucks for a new IAC and the problem stopped. Didnt even install the new part, the problem just cleared up and never came back. That was two years ago. Still have that damn IAC sitting around somewhere.
__________________
2000 Excursion V10 4x4 4.30s
2000 F250 Super Cab V10 4x4 4.30s (gone).
2004 Mustang GT 5Spd.
  #14 (permalink)
Old 08-25-2008, 12:55 PM
78crewcabjohn 78crewcabjohn is offline
78crewcabjohn is starting off with a positive reputation.
I had some stalling issues....check my posts for the solutions. One was the IAC and the other was a MAP sensor cleaning. JOHN
  #15 (permalink)
Old 08-25-2008, 01:41 PM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
I would inspect for a vacuum leak as well. While the IAC can be a culprit, the fact that the dealership changed the brake booster can mean that a hose got kinked, torn or not put back on.
__________________
Ken
Cats; nasty creatures...
Tags
7m101 , aa , bad , coil , f81z , p0720
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
