04 f150 extended cab rear door won't open
Old 08-15-2008, 11:03 PM
tomgarnett's Avatar
tomgarnett
tomgarnett is offline
Unhappy 04 f150 extended cab rear door won't open
The driver's side rear door will not unlatch at the bottom when the handle is pulled. The top latch works ok. Problem is, how do I get the door open to remove the panel. The handle is retained by what appears to be pop-rivits. I'm hesistant about drilling these out, fear of not finding a way to reinstall the handle. Any help would be appreciated
Old 08-15-2008, 11:08 PM
AzBlueWolf's Avatar
AzBlueWolf
AzBlueWolf is offline
try gently prying off the inner door panel...
there should be a rod or cable going to the latch and it either is disconnected or broken
you should be able to pull on the rod or cable to release the latch
good luck!
danieldmp08
07-17-2015 10:35 PM
LeoJr
10-19-2013 11:34 AM
SunBum
04-01-2013 01:34 PM
BroncoRN
11-12-2012 09:23 PM
Jacksfirstdiesel
20
05-19-2010 12:01 AM
Quick Reply: 04 f150 extended cab rear door won't open
