04 f150 extended cab rear door won't open - Ford Truck Enthusiasts Forums
Old 08-16-2008, 12:03 AM
tomgarnett tomgarnett is offline
tomgarnett is starting off with a positive reputation.
Unhappy 04 f150 extended cab rear door won't open
The driver's side rear door will not unlatch at the bottom when the handle is pulled. The top latch works ok. Problem is, how do I get the door open to remove the panel. The handle is retained by what appears to be pop-rivits. I'm hesistant about drilling these out, fear of not finding a way to reinstall the handle. Any help would be appreciated
Old 08-16-2008, 12:08 AM
AzBlueWolf's Avatar
AzBlueWolf AzBlueWolf is offline
AzBlueWolf has much to be proud ofAzBlueWolf has much to be proud ofAzBlueWolf has much to be proud ofAzBlueWolf has much to be proud ofAzBlueWolf has much to be proud ofAzBlueWolf has much to be proud ofAzBlueWolf has much to be proud ofAzBlueWolf has much to be proud ofAzBlueWolf has much to be proud ofAzBlueWolf has much to be proud of
try gently prying off the inner door panel...
there should be a rod or cable going to the latch and it either is disconnected or broken
you should be able to pull on the rod or cable to release the latch
good luck!
'96 E150 Rear Passenger Door Won't Open danieldmp08 1968-2013 Full Size Vans 2 07-17-2015 11:35 PM
Door opens at the last bit of handle pull? LeoJr Explorer, Sport Trac, Mountaineer & Aviator 2 10-19-2013 12:34 PM
rear door won't open, how can I fix it??? SunBum Excursion - King of SUVs 8 04-01-2013 02:34 PM
Door handle pull? BroncoRN Excursion - King of SUVs 2 11-12-2012 10:23 PM
inside drivers door handle broke off Jacksfirstdiesel 1994.5 - 1997 7.3L Power Stroke Diesel 20 05-19-2010 01:01 AM
Tags
150, 2009, back, cab, door, doors, extended, extented, f150, ford, handle, open, opening, rear, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
