94 Lightning Mass Air Flow conversion?
I Converted my truck to mass air flow by a donor truck with mass air flow.I just switched everything over i did not buy the aftermarket kit.I need a wiring diagram or directions how to wire up the driver side o2 sensor?My truck is running to lean Bank 2 because it does not have the driver side O2 sensor.They told me to come to this site were some of you guys have done this or can help me thanks.
The National Lightning Owners Club Inc - Powered by vBulletin
Have you tried that site.. Real good for lightning info..
I tried NLOC already they helped a little.I used a 95 f150 5.8 and computer that i used is MOB1.I tried to look up the MOB1 and i cant find were it came from?They have told me to use the AKCO,Some came with one O2 sensor i just need to know if they came on the F150s only or if they came on the vans or cars so i can keep a look out for it in the junk yard?I think its easier to change computers than to wire up a second O2 sensor.Any help would be good thanks.
The AKC0 was specific to the GEN 1 LMAF conversion, and it only uses one O2 sensor, as well as almost all of the other EEC-4/MAF/E4OD/V8 ECU's. The thing with the AKC0 is that the injector tables are mapped for 30lb squirters; you'll need the air meter that came with that kit and a set of 30lb injectors if you don't plan on any aftermarket tuning.
There are a few other mass air 5.8 ECU's that'll work fine with your motor and transmission combo; WAY1 or VEX1 . The 302/MA/E4OD ECU's will also work but fueling and timing will be off slightly because of the displacement differences
As far as I know, they only need one O2. Finding any 5.8 or 5.0 MAF EEC-4 ECU with an E4OD shouldn't be too hard. The 5.0 types are probably going to be easier to find.
the WAY1 will work it has only 1 O2. there are remans available from PartsAmerica.com f5tf-12a650-jb... i got one! well 2 now... and it running a 427w stroker with a chip. I learned from my tuner that the EEC will adjust/ learn up to 25% of its normal range so a 351 on a stock 302 eec is not impossible. as long as you dont get too radicle!
BTW, the way1 and the vex1 are federal emmissions not california.
anywhere you can find one! partsamerica was my best source. A word of advice , i dont know how you plan to do your harness, but the way ford did the conversion kit is about the easiest and cleanest way to go. you'll need to visit a local scrapyard and retrieve a factory harness and a , preferably dead eec. for donor parts. i used a 89 crown vic because it layed out just right.
I also combined the cv harness with the OEM truck harness rather than making a intermittant/ go between harness like ford did. i just saw one tonight and it looks a lot cleaner than my jumbled mess. i'm planning on remaking mine like theirs... <<< is that copyright infringement??? i guess as long as i don't sell it for profit!
oh i foregot, somewhere on nloc some guy posted pics of the entire kit... if you can find it. im still looking. whomp.. here it is!
http://www.nloc.net/vbforum/faq-sect...-kit-pics.html
I used original harness from my donor truck i just had to move and extend some connectors but everything worked out good.My Lightning runs good with MAF my only problem was to lean bank 2.Hopefully the computer you recommended WAY1 will solve my problem.I just have to find it.Thanks for the help termyt00.
