Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-13-2008, 02:28 PM
dcwhipple's Avatar
dcwhipple dcwhipple is offline
Garage is empty, add now
dcwhipple is starting off with a positive reputation.
Question 1st Dr Pepper Attempt
Don't think it worked...
1) Got some WVO from the local Mexican place down the street about a month ago and let it sit.
2) Scooped a liter of murky golden oil off the top.
3) Took to boiling point (~260 f) and saw very tiny bubbles...no boiling so seemed H2O free.
4) Let cool to ~ 140 f and put in 2 liter bottle.
5) Added the fully diluted mix (250 ml (most of the yellow bottle) of HEET + 1 tsp of lye from Lowes).
6) Shook for 5 seconds 4 times over 1 hour.
7) Let sit for 48 hours.
The oil started murky gold and is now murky gold with a 2 inch layer of black gook at the bottom of the 2 liter soda bottle. It's like a lava lamp! I do not see an appreciable difference between the before and after color and opaqueness of the top part.
Is it just that the oil was THAT BAD and I need to run it again or perhaps I need to "wash" the rest of the crud out? Heaven forbid that I did something wrong
__________________
-Dan PAA MEMBER #68...just missed 69, the story of my life
00 F350SC Auto 4x4-6637
www.7point3.com
http://search.ebscohost.com/ usr/pw:library
Powerstroke trouble code descriptions
  #2 (permalink)
Old 08-13-2008, 03:14 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
I suspect your technique is wrong.
first you chemistry seems to be off.
did you get complete disolution of the lye in the heet
I have heard that heet is not the best source of methanol (I have never used it just read that in a few places)
Your agitation techniqe was inadequate.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 08-13-2008, 03:54 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
#1. Did you do a Titration?
#3. Those "tiny bubbles" ARE water, and can effect the process.
#5. How many grams is 1 tsp? What type of "Lye"? What strength?
#6. You should have shaken the s*** out of it for at least 5 min.
Definitely under-processed............
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 08-13-2008, 03:56 PM
dcwhipple's Avatar
You could be very well right?!?!? I just followed the 'Making A Small Batch' instructions on biodieselcommunity.org
Can you please help with a little more detail around the chemistry being off? They say 250ml methanol (about 1 cup, right???) and 6g NAOH (about 1 tsp, right???)
The solution DID completely dissolve into a clear liquid before I put it in with the oil. Took about 5 minutes of hard shaking in a closed mason jar.
Would also like additional detail on proper agitation as well as any suggestions on where to get a better test methanol source if HEET is no good.
Sorry for the basic questions...I was hoping enough research in advance would result in a positive result but I was obviously wrong.
Thanks!
__________________
www.7point3.com
  #5 (permalink)
Old 08-13-2008, 04:03 PM
dcwhipple's Avatar
First...Thanks for the input. (forgot to say that last time I posted)
#5. instructions say that 1tsp = 6-7g and I used Roebic 100% Sodium Hydroxide.
Sounds like I need to try test batch #2.
__________________
www.7point3.com
  #6 (permalink)
Old 08-13-2008, 06:06 PM
tradergem tradergem is offline
tradergem is starting off with a positive reputation.
HEET is only 99% methanol with 1% proprietary ingrediant per this MSDS: GAS LINE ANTIFREEZE
I don't really know, but I think that extra 1% proprietary ingrediant may be the problem.
Good luck. Jim
__________________
1990 F250 XLT 7.3L N/A E4OD 4X4 4:10 axle ratios
  #7 (permalink)
Old 08-14-2008, 02:07 AM
blkbeast blkbeast is offline
blkbeast is starting off with a positive reputation.
I did all my first test batches with yellow Heet without too many problems. You may not have had enough lye in the mix. I think the base for new oil is around 5g per liter so used oil would be more than that depending on the titration. When I did the Dr pepper method with used oil I just used twice the lye they called for.
  #8 (permalink)
Old 08-14-2008, 09:37 AM
Phydeaux88's Avatar
Thanks!
It is really difficult to get close to accurate weight of a crystaline solid by measuring volume because you can't take the density (how tightly packed) into consideration. I also dont know how pure the lye and or HEET you used was.
You are correct that 250 ml is approx one cup
To measure the lie try a dixie cup scale:
Dixie Cup Scale - Collaborative Biodiesel Tutorial
remember to use distilled water for the standard weight (water from your faucet has to much junk in it so it is heavier than distilled)
go buy a cheap medication dispensing dropper to measure the water with.
Mexican Food places tend to use the oil for a long time and that causes a heavy buildup of FFAs. For that reason you really should titrate to get accurate an measure how much NaOH you need.
http://www.biodieselcommunity.org/titratingoil/
As far as proper agitation goes ya really need to shake the s*** out of it for for at least 5 mins.
Dont give up it is worth the effort and you will get there. Many here have tried several times before succeeding.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
