Fog Light lens cracking
I was washing the truck the other day...and noticed the fog light lens are both cracked. They are not leaking or holding water inside..but the plasic lens are cracked badly. I do use the fog lights quite often....maybe the heat from the bulb? Anyone else have this happen? I will try to snap some pics of them tonight...if I can remember.
Same exact thing happened to me....your crack and my crack look the same...luckily it happened within the first month I got the truck and the dealer fixed it for me for free. I use my fog lights all the time. Because it happened so quick from me getting the truck my thinking is that it was a rock. Have not had the problem since.
Looks like rock damage to me...
If the dealer is unwilling to do anything about the cracks, I might suggest wicking some thin superglue into the cracks to keep moisture out unless you're going to replace the lights or lenses really quickly.
As for fog light use, if your lights are the kind that aim into my rearview mirror, I'd ask you not to use them unless there is really fog...
