3" intake manifolds w/stock fuel bowl?
on
1 Post
Neal you will be boarder line. I would guess you will be a hair under 40 psi. But that is not a hard and fast rule. Another thing to think about is valve springs. I don't know how many miles are on your motor but the higher boost pressures also start to push the intake valve open. Some procomp 910-16's might be a good investment ($100).
Thats some good information to know TJ! I'm gonna have to look into those intakes. Where'd you get the Neal?
Well thats for the billet aluminum ones, i thought that they had other ones but they changed the site since the last time i was on there and i cant find them anymore. But if i remember right they were 3" steel ones and like 250. But thats just a guess cuz its been a while since i looked at them.
You're gonna be real close to where you should have them. With BDP stage I's I was was seeing 35 psi and the MiniMe's brought it up to over 40 with the CAC delete pipe. I ran like that for almost a year before I finally did studs and the 6.0 CAC.
If I were going to get aluminum intakes I think I would get these
Product View
Product View
Neal if you got spend it. Its my motto!
Big buck 7.3 intake in link.
Mercury & Mercruiser Parts, CUMMINS/MERCRUISER DIESEL 7.3L D-TRONIC BRAVO, Aftercooler and Intake Manifold
Bill
Bill
#29
And I thought I knew how to post pics on here. That was supposed to be a thumbnail you could click.
Here's a link to the picture:
pictures from trucks photos on webshots
That's 3" SD steel intakes and a hypermax "Y" and IC delete pipe
#30
on
1 Post
Bill
Bill
