Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 08-12-2008, 11:29 AM
EXPhottie EXPhottie is offline
Garage is empty, add now
EXPhottie is starting off with a positive reputation.
HID conversion kits
Just found this place and I have to say incredible amount of good information. I have a 2007 Exp EB. I was looking into upgrading the lighting with an HID plug and play kit like this:
index
Has anyone tried these kits yet? I was looking into just upgrading bulbs or even the sylvania silverstar bulbs, but worry about the higher wattage and damage to the terminals:
Hella H13 Replacement Bulbs
What type of problems if any with bulb upgrades has anyone run into, and do they really make a difference over stock bulbs?
  #2 (permalink)
Old 08-22-2008, 09:22 AM
STILLEN/EXEPIDITION's Avatar
STILLEN/EXEPIDITION STILLEN/EXEPIDITION is offline
STILLEN/EXEPIDITION is starting off with a positive reputation.
There are many compaines out there that have direct fit HID kits some as inexpensive as $98.00. And there are ones for over $300... There are no differance from the two except the pricing. I have 4 sets of HID 's on My Expy. Low Beam /High Beam and both sets of Lower fog lights all at 10k... And let me tell you on a Dark road with all of them on... Looks like a 747 landing...lol Now as for replacement bulbs if you stay with the same wattage you will be fine some bulbs are higher wattage and your stock wiring can over heat. Plus side its cheaper than HID kits down side you can Ruin your wiring.
__________________
  #3 (permalink)
Old 08-22-2008, 03:44 PM
Thanks for the response, which kit do you have if you don't mind me asking?
  #4 (permalink)
Old 08-22-2008, 04:19 PM
Each one is 10k, which I happen to like the output and color...
XenonLink.com HID Conversion Kit.
__________________
  #5 (permalink)
Old 09-12-2008, 09:04 AM
williamsplumbing williamsplumbing is offline
williamsplumbing is starting off with a positive reputation.
OK, I went and bought the HID light kit(s) and I must say the service from the seller was more than great. Ordered them Wednsday and recieved them Thursday afternoon. Now, in order to save time, looking at the kit, I see it has a bracket for the ballast, are there pre drilled holes to bolt this to, or am I on my own in that regard?
Might there be a link to a Ford manual that shows the headlight set up for the 08 Expedition?
  #6 (permalink)
Old 09-12-2008, 09:18 AM
The brackets can be installed almost anywhere as long as you have the reach for the cables to be pluged into the headlight. other that that it should be simple plug and play wiring...
__________________
  #7 (permalink)
Old 09-12-2008, 09:56 AM
I've pulled the two bolts at the top of the headlight: what is still holding the headlight in place? I tried pulling up and it won't come hot. In as much as I still don't have 1k miles on it, I don't want to start prying on some thing.............
  #8 (permalink)
Old 09-12-2008, 01:23 PM
myexpo02's Avatar
myexpo02 myexpo02 is offline
myexpo02 is starting off with a positive reputation.
If you can...take some pics of your set up...I would be interested in a setup like that.
__________________
2002 Expedition XLT (2wd with 4R100 auto) with 146k...traded on an 2008 Expedition XLT (2wd with 6R75 auto)Heavy tow-package, DVD,18"Chrome Clad wheels,Leather and ScanGauge II.
  #9 (permalink)
Old 09-12-2008, 01:38 PM
hjsimpson's Avatar
hjsimpson hjsimpson is offline
2007 Ford Expedition
hjsimpson is starting off with a positive reputation.
Would you happen to have any pictures of the install or any night shots?
Where did you mount the ballasts?
__________________
2007 Ford Expedition XLT 4X4
Husky Liners Molded Mud Guards ~ Ford OEM Side Window Deflectors ~ WeatherTech Floor Liners & Cargo Liner
Tinted front windows ~ Hunter Bull Bar ~ HIDX 4" HID lights ~ 4" Magnaflow SS rolled angle exhaust tip
Quote:
Never, never, never give up. -Winston Churchill
  #10 (permalink)
Old 09-12-2008, 01:45 PM
Stillen/Expedition has to reply. I opened the box, understood the wiring diagram- but quit when the headlight assembly didn't immediately come out. I'll go back and play with it some more or go ahead and do the fog lights, coming back to the headlights.
  #11 (permalink)
Old 09-12-2008, 09:44 PM
HID Lights
I was able to install 1 of the fog lamps this afternoon, loads of fun.......the "bracket" for the igniter was the hard part. I used a self tapping screw to afix it to the cross member that runs under the radiator. That required an angle drill and a trip to the hardware store for a set of "colbalt" bits. (any excuse to buy tools). So, one screw at the bottom and sticky tape in the center. The igniter has to be in the bracket when installed, as there is not room to install it later. One light is functioning and the other will take about a forth of the time in the morning.
  #12 (permalink)
Old 09-13-2008, 02:09 AM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
2001 Ford Excursion
RACERX7775 has a good reputation on FTE.RACERX7775 has a good reputation on FTE.RACERX7775 has a good reputation on FTE.
10k for the color has pretty much the worst output available. the lower the temp, the higher the output. 4300-5000 is the best for output. the reason for the 747 thing is because of the quantity of lights and the horrible glare. the truely best way is to do a set of custom fabbed hid projectors into your factory headlights.
Click the image to open in full size.Click the image to open in full size.
__________________
ROB
01 EXCURSION LIMITED, 4X4, V10, 5" LIFT WITH TRACTION BARS, 325/60/22 (37") BFG AT's ON POWDERCOATED WHEELS, 07 SUPER DUTY FRONT END, REAL BILLET DOOR HANDLES AND FUEL DOOR, 6 TV'S, CUSTOM STEREO, CUSTOM BUILT 500 AMP ALTERNATOR AND FIVE GEL CELL BATTERIES, CERVINI 3" COWL INDUCTION HOOD, CUSTOM MADE HID PROJECTOR HEADLIGHTS AND 55 WATT HID FOG LIGHTS, CUSTOM TWO-TONE PAINTJOB
  #13 (permalink)
Old 09-13-2008, 09:56 AM
Thank's, but where were you when this subject came up and I spent the money? lol!
  #14 (permalink)
Old 09-13-2008, 10:04 AM
I could still use the info from the Ford manual about the headlights, but, alas, FTE say's I'm lowly and don't have sufficent privilege to answer the email from the fellow who offered them...........
  #15 (permalink)
Old 09-13-2008, 10:56 AM
RACERX7775's Avatar
2001 Ford Excursion
you have to have 25 posts for that one.... oh, sorry for being late on this...i never stroll out of the super duty and excursion forums..
__________________
ROB
Tags
1999, 2001, 2007, alternators, conversion, dual, expedition, ford, headlights, hid, install, lights, metric, range, rover, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
