You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I just pulled the air cleaner off my 534 expecting to be able to pull it apart and clean the filter element, but it appears the top section does not come apart. What type of element is in there and how do I clean it?
The way I clean oil bath cleaners, although it might not be the best possible way to do it, is:
1. Pull the bottom bowl off
2. Depending on the style, there may be removable screens stacked on top of each other. Separate them and clean them with brake cleaner or other similar product.
3. Dump out old oil and clean any sediment out of the bowl.
4. If theres other baffles in the housing that arent removable, just spray some cleaner in there and let it drip out.
5. Finally, reassemble with fresh oil
__________________
2002 Dodge Ram 2500 5.9 24v autotragic
1996 Ford Bronco Eddie Bauer
1993 Ford F350 7.3 IDI turbo 5 speed crew cab-Garret cold side, ATS hot side and dp, custom exhaust, gauges, 15psi-sold
1989 Ford F350 4x4 351 5 speed-The Beast-SOLD
1984 Ford F250- my project- -SOLD
