Will a 300 Straight-6 replace my 302??
Hello again fellow Ford fans,
Question - will a 1983 300 straight 6 cly. fit my truck, a 1982 with a 302?? will the 6cyl just take the place of my broken 302, or will i need to do anything special? I know nothing about changing out engines so please someone respond if you know the answer. thank you!! my email is jaredpared@gmail.com and my phone number is 6087905352.
and of course I am still looking for a replacement for my beat-up 302, would be nice to find a good runner locally - La Crosse WI -
While the 300 will provide the torque just above idle, it runs out of steam quickly over 3000 rpm. If your gearing will tolerate that, you'll be happy with the 300.
However, this engine change will involve the cooling, as per prior post. AND the exhaust, throttle linkage, and the accessory drives. Not rocket science, but lots of little things compared to swapping in another 302.
Good luck.
Good luck.
I did the opposite several years ago; I had an 84 that had a very abused I6 that I ended up swapping for a 351W. It was a pretty easy swap, mounts and radiator were the biggest things but I don't remember any real problems. That 300 was a great low end pulling motor it was just sloooowww.
302s usually start cooking at 3000....is the exhaust squashed flat?
THANK YOU GENTLEMEN!! All of you are very kind for taking your time to write out your opinions for me. I've decided to NOT purchase the 300 I-6cyl, I'm going to try to find either another 302 to just slip right in, or maybe something else, i don't know.
thanks again guys!!!! jared jaredpared@gmail.com
I think it would be better said that their big difference is that one operates more efficiently at lower rpm, the other at a higher rpm.
I have a friend that might take issue with that description .... he's cranking in excess of 300 hp out of the 300-6 he has in his pickup. I've had my share of 302's in pickups, T-Birds and Grand Marquis and you'd have to put as much money into an engine as he did to call a 302 a "racing motor".
