Wiring Harness diagram - Ford Truck Enthusiasts Forums
Old 03-30-2002, 09:27 PM
lshort lshort is offline
lshort is starting off with a positive reputation.
Old 03-30-2002, 11:26 PM
mrbassn mrbassn is offline
mrbassn is starting off with a positive reputation.
Post Wiring Harness diagram
I have a 71 f100 4x4 with a 360 ci in it. I took out the stock wiring harness and put in a painless wiring harness. I was wondering if anyone could send me or tell me where I could locate a wiring diagram for my truck.I am finding things hard to locate on the stock harness .Also where the voltage reducer is located so I can add it to the painless harness.Thanks MrB.
Old 03-30-2002, 11:44 PM
I have the diagrams for a 71 (I think) what do you have a question about as the diagrams are quite large.As far as a voltage reducer
in a 71 I think a 71 has a instrument voltage regulator is this what you are talking about?They are on the back of the instrument panel.
Larry
Old 03-31-2002, 12:08 AM
sparky's Avatar
sparky sparky is offline
sparky is starting off with a positive reputation.
It is a red/green striped wire, probably looks like a black stripe though, that every few inches says "resistor wire" if my memory serves me right, but it also could be "resistance wire". Darn memory loss
It runs from the ignition switch to a splice located just inside the firewall above the drivers left knee. Where it joins a brown wire from the ignition relay and another red/green wire to the coil +
Sparky
Old 03-31-2002, 12:11 AM
I think i figured out the voltage reducer you are talking about.Is it the resistor wire for the coil?This is located in the wireing hareness.Look at the coil.I think it will have two wires on the + side one will go to the I terminal on the starter relay.The other will go to the ign switch.This is the resistor wire.If you are going to reuse the resistor wire it has to be stretched out not coiled up or doubled back on itself.As it will get to hot.
Old 03-31-2002, 12:21 AM
[updated:LAST EDITED ON 31-Mar-02 AT 00:22 AM (EST)]Thank you very much Larry.I was wondering if you could possibly send me those diagrams via email? It would be greatly appreciated.My email address is potter87@worldnet.att.net
Old 03-31-2002, 03:21 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Chrysler used a resistor module that could possibly be used. They were mounted on the firewall of 60-70's chrysler products. My books listed the value of the Chrysler unit as 0.5 to 0.6 ohms, two of these units in series (end to end) would produce 1.0 to 1.2 ohms. According to my books the value of the resistance wire for Ford is 1.3 to 1.4 ohms. This is probably close enough to work just fine.
When you wire connections to the ballast resistors use high temperature wire connectors and good wire. You can get these connectors at appliance repair dealers. They use them where they connect to heater elements etc. They are cheap, often they will give you a few.
Just an alternative...
over!
Old 03-31-2002, 07:41 PM
I do have the diagrams for a 71 but I dont have a scanner so I have no way to send them to you.If you Have a certain question about the 71 wireing I will try to find the answer.
Larry
Old 04-02-2002, 12:49 AM
Larry thanks....I neeed to know if there is a relay of some sorts attached to the heater fan switch? Or if not what plugs into the factory plug I have at the end of the heater fan swithch plug it takes three prongs? Thanks MrB.
Old 04-02-2002, 01:00 AM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
The speed resistor.
It attaches to the plenum.
Dennis
[font color =red]Calgary,Alberta,Canada [/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color =green]http://www.clubfte.com/users/mil1ion/Mil1ion.html[/font]
[font color =green]http://community.webshots.com/user/mil1ion[/font]
[font color =green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
Tailgate mods 1978 - 1996 Big Bronco 6 05-25-2002 04:08 PM
Cams broom FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 8 11-24-2001 01:46 PM
Tags
2002, 40, 46, automotive, diagram, diagrams, didagram, ford, harness, pickup, truck, trucks, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
