Are NAPA brake pads any good ?
Old 08-11-2008, 06:58 PM
maevans's Avatar
maevans
maevans is offline
Has anybody ever use the NAPA front brake pads - # SD-7625m that sell for $82.00. The parts guy tells me they are for SD that tow's heavy trailers.
Or can anybody recommend another brake pad for towing, I plan on changing them this weekend. so i need to get them order if i don't use the NAPA pads.
The wife and I went up north to try out our new ATV and on the way home rounding a curve, There stands three deer, It took all i had to get the truck and toybox stopped.
I almost filled all of my deer tags before the season started. (again)
Old 08-11-2008, 07:04 PM
jesse5's Avatar
jesse5
jesse5 is offline
Napa's most expensive pads are good. The one's you mentioned lasted me three years and seventy thousand miles which is good. You can also order Performance Friction through AutoZone and they cost less.
Old 08-11-2008, 07:12 PM
derekmj64's Avatar
derekmj64
derekmj64 is offline
I have them on my truck and I was towing my buddy's 25' steel car trailer without trailer breaks and on it was a Geo tracker, 2 dirt bikes, and a 4-wheeler and it stopped better than I expected when we came up to a traffic jam. I would recommend them. I have always used NAPA products even when I had my Bronco.
Old 08-11-2008, 07:15 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
FTE/PARTS-GUY is offline
Former Vendor
Ford Motorcraft makes a Heavy duty brake pad. very affordable.
BRSD756
made for fleet use.
Ed
Old 08-11-2008, 08:50 PM
rebelchevy02's Avatar
rebelchevy02
rebelchevy02 is offline
The OEM pads, from the dealer last about 100k. Every set on our trucks has. I got one set of medium grade carquest ones once. Lasted 30k. I always had gotten medium grade carquest ones for everythign untill then. (usually the high grade ones are called rotor chewers, and low grade are well, low grade) OEM ones at cost are usually 120 bucks IIRC. Other then that, I would consider the Hawk pads, that most people seem to like so much.
EDIT: And yes I tow, and gross 18k or so when I do tow, we have two skidloaders, and other heavy junk that needs towed from time to time.
Old 08-11-2008, 08:57 PM
Hiflyer746's Avatar
Hiflyer746
Hiflyer746 is offline
OEM pads seem to last a while. . . but when they get overheated they will last forever. . . because they no longer perform and braking action. I would not recommend OEM pads for any aggressive braking. I drove way too long with my overheated brakes and i guess I got lucky. I have EBC's right now and I'm not super happy with them either. they squeak and they don't stop as well as I would like. In fact I can't really get them to lock up the tires. Not acceptable in my opinion. I will be putting hawks on mine next.
Timmy
Old 08-11-2008, 09:57 PM
pbr man's Avatar
pbr man
pbr man is offline
I teamed up a set of Napa preminum pads with Powerslot rotors It is like night and day on stopping from the oem pads and rotors that I replaced.
Old 08-11-2008, 10:28 PM
tag187's Avatar
tag187
tag187 is offline
My friends and myself swear by Hawk on our trucks but we use napa pads on the fleet trucks at work with no issues yet, and all the above mentioned trucks are used on the regular to tow 16k+.
Old 08-12-2008, 03:30 AM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
i have had these napa pads on for a little over 50k miles with no problems...not even half worn out yet...
brake pads rear
ceramic ss-7626x
brake pads front
ceramic cmx-7625
Old 08-12-2008, 05:10 AM
maevans's Avatar
maevans
maevans is offline
Thanks guys for all the repleys, Very helpful..
I think I'll give the NAPA pads a try this weekend.
Ron - Do you ever sleep ? Today, 04:30 AM <!-- / status icon and date --><!-- / status icon and date -->
Old 08-12-2008, 07:46 AM
Dukernc's Avatar
Dukernc
Dukernc is offline
Hey Mark,
Just did a front brake rebuild on my 90' F150 and installed the premium NAPA SD pads along with the premium grade rotors. The combination works great! It stops on a dime and gives you change!! I also have the SD pads on my 99'. Just be sure that what ever pad you choose to use that you perform the "bedding" break-in process. FYI .. if your not familiar with the process..
BRAKE PAD BEDDING IN PROCEDURE
Good Luck!!
Old 08-12-2008, 08:35 AM
psdme's Avatar
psdme
psdme is offline
You may also want to consider the "emergency vehicle" rated pads for a few more $'s.
~paul
Old 08-12-2008, 10:17 AM
cangim's Avatar
cangim
cangim is offline
I put the rear pads on my truck in Rons post above after I first got the truck several years ago. They didn't even look worn much when I pulled them off a year ago or so. Replaced rotors and pads all around. Package deal type thing. I would definately use Napa again. I buy most all my parts from Napa, seems they usually carry what I am looking for.
Old 08-12-2008, 11:30 AM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
I have no problem with NAPA pads but every rotor I have put on a vehicle from them warp in no time flat. I will NEVER use their rotors again. My .02
Old 08-12-2008, 02:53 PM
ron's power stroke
im up by 4am every day..3 am alot of the time...make sure you brake them pads in when you put them on..they work better and last longer that way..
Brake Tech - Brake Pad and Rotor Bed-In Procedures
there rotors do suck..but get you out of jam when you need to be running,,,
Quick Reply: Are NAPA brake pads any good ?
