Pay load capacity on F250
also depends on how much his truck weighs to start with. mine is just a reg cab xl and it weighs 5500 lbs. so i could handle a 3k lb pallet and still be under 8800 lbs. its handled it fine on many occasions. but once you start adding an extended cab, tool boxes, bigger tires, etc, you use up that 8800 lbs a lot faster than you think. so yeah, your truck will handle 3k lbs no problems. but unless you have just a bare bones truck, it wont do it legally. just my opinion, but if youre hauling it 2 miles from lowes to the house, i wouldnt worry about it. but if youre going to be on the road for any length of time i would stay legal. not because the truck wont handle it, but because like the others said, if you have a wreck, whether its your fault or not, insurance wont pay for it if you are overloaded.
i dont know about the obs, but on the 99 to about 04 or 05 superduty, the only difference between the 250 and 350 is the 350 has a 4" block and the 250 has a 2". at the end of the day, they will handle the exact same load with the exact same ease, but the 350 gets that 9900 rating because it has a different sticker on the door.
bkvanbek
11-26-2013 06:05 PM
oig2scout
12-06-2009 10:47 PM
