Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-10-2008, 10:27 PM
Knotwild Knotwild is offline
Garage is empty, add now
Knotwild is starting off with a positive reputation.
Magnesol/Engine Wear
I guess this is a question for someone who really knows diesel engines, or perhaps a beware statement. I just got my engine oil analysis back from Blackstone and my lead reading (indicating bearing wear) went from 3 to 4 ppm for three previous tests to 19ppm. Blackstone indicated that the high lead could be temporary and caused by a particle streaking a bearing.
The 19 ppm test came after using Magnesol to drywash and filtering it through a 1 micron absolute filter on the way to my truck's tranfer tank. Then it goes through a micron nominal filter on the way to my truck fuel tank. The only other variable is that I used a K&N oil filter instead of my usual Napa Gold. I don't trust K&N products after reading this forum. But one of two things happened or a combination;
1: The K&N filter let me down and a particle/particles of debris streaked my
bearings.
2: The Magnesol is somehow getting into my oil.
All of the other oil test parameters besides the lead for this test were in line with the previous 3 tests. Only the lead was significantly higher.
So, the questions are: Can particles 1 micron and smaller hurt an engine and would it wind up in the oil in particle sizes large enough to affect the bearings considering it was filtered so fine (remember, 1 micron is bacteria sized) and it went through combustion? If it were the Magnesol, would it not show increased wear in other areas also? Is bearing streaking something that probably happens to a lot of engines and we just don't know it without engine analysis?
And, if particles in fuel filtered to 1 micron can damage an engine, why is Caterpillar leading the industry in using a fuel filter that is 2 microns?
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
Tags
150, biodiesel, forum, magnesol, particle, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
