Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-10-2008, 07:36 PM
archangel archangel is offline
Garage is empty, add now
archangel is starting off with a positive reputation.
I built a Smack booster and need advice.....
I guess the HHO thread (a form of alternative fuel) is in the IDI 7.3 diesel page?
Oh well, here it goes.
I built a Smack HHO booster and after testing decided the instructions on line were off.
It said to cut the cell main body 12 inches long.
I did, and the over all cell height was over 16 inches and looked a lot longer than those pictured on line and they mention the over all height as 12 inches.
I reread the instructions and it does say to cut the main tube 12 inches.
Well, I decided to cut it shorter to match those pictured on the web site so I pulled the guts out to cut the main tube shorter.
Here is the issue I have a question about.
I noticed that there was a dark scorched kidney shaped looking patch on the outer plate surface above where the clear shrink wrap (made from a 2 liter bottle) comes in contact with the cell and pulls away to cover the top cell bolt.
Is this scorching normal?
I think it might be an issue that the area is exposed to reaction fluid but reduced fluid flow from the shrink wrap and is overheated.
It does look like the other cell plates are darker on the closer, reactive surfaces, and that might be a normal darkening of the plates, but I have not read about a darkening of the cell plates and am unwilling to tear it down to inspect the cells until I'm done testing it on my 7.3 IDI and have the next, bigger, more advanced cell unit built and ready to hook up.
  #2 (permalink)
Old 09-19-2008, 10:05 PM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Fullcrew7.3 is gaining momentum as a positive member of FTE.Fullcrew7.3 is gaining momentum as a positive member of FTE.
I'm just looking into setting one up for myself. haven't even had a chance to gather parts yet. A guy at my workplace has a running unit on his pickup. I haven't seen it, but talked with him a bunch about it. The reaction is rather exothermic (creates heat as a biproduct) and can melt/scortch stuff if not cooled in some way. This guy took a little water pump from a table top fountain, placed it in the bottom and ran a long hose looped in front of his rad to cool the water down. This may not be related to your specific problem. Sounds more like the hydrochloric acid produced in the process is corroding your plates a bit.
__________________
Fullcrew7.3
Dave
1996 F350 CC 7.3L PSD DRW, DIY 4x4 conversion, 4.10 gears, Sky 3" RSK, DIY 4" exhaust, 3" diamond eye DP, SC 1705, Stage 1 Rosewood sticks, Valair SMF, SD I/C, 37/12.50/16.5 wranglers and some more DIY stuff
Tags
2000, 42, booster, cell, directory, f150, ford, hydroxy, litre, review, reviews, smack, smackbooster, smacks, specs, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
