Emission diagrams - Ford Truck Enthusiasts Forums
Emission diagrams
Old 08-10-2008, 06:46 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
Emission diagrams
I have searched through, and can't exactly find what I need. I am trying to find a vacuum diagram for a 1977 F-100 49 state truck with a 351M and C6. The truck is catalytic converter equipt, air pump, evaporative system and EGR. My experiance with 1977 was an F-150 originally with a 300 later a 390 4V camper special engine. Thanks for any help.
Old 08-10-2008, 09:42 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
Old 08-10-2008, 09:59 PM
Thank you, that should help. It has a wierd vacuum regulator valve that some diagrams show in the EGR line and a thermal delay, I think, in the side of the aircleaner.
Old 08-10-2008, 11:28 PM
fmc400's Avatar
MSEE
Some old setups did put a delay valve inline with the EGR vacuum. This was an effort to combat driveability issues with smog motors back in the late 70s.
The air cleaner vacuum routing is a separate system and unfortunately I did not put it in my drawing for clarity. The air cleaner vacuum routing is for the hot-air intake system; it is used to draw in warm underhood air during warmup instead of cold outside air to prevent the carburetor from icing up. All it is, is a line from manifold vacuum (can grab it from the vacuum tree) to a bimetallic switch in the air cleaner. Another line goes from the same switch to the vacuum diaphragm on the snorkel of the air cleaner. Some setups included an inline check valve as well, to keep the air door in the snorkel from opening back up during periods of low vacuum.
Old 08-11-2008, 06:15 AM
I knew about the air cleaner preheat. This is a valve in the side of the can. From what I have found, this beast apparently has California emissions, why I don't know. Thanks for your help.
1977 F-150 Replacing Steering Wheel Bubba Hines 1973 - 1979 F-100 & Larger F-Series Trucks 20 10-23-2015 08:10 AM
84 vac line tn1977 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-30-2015 06:44 PM
1977 f250 fuel selector hose diagram with 3 tanks 77truck460 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-04-2014 11:37 AM
Harley HarleyP 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-02-2014 08:44 AM
Wiring Diagram 77 f150 Idonttkknow 1973 - 1979 F-100 & Larger F-Series Trucks 1 12-17-2005 11:27 PM
Tags
2010, diagrams, emission, ford, ranger, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
