Removal of tensioner arm pulley
Old 08-10-2008, 10:40 AM
PatchMcGav's Avatar
PatchMcGav
PatchMcGav is offline
Been hearing a loud sound from engine, so i did some research found out it could be the pulleys. So i pulled the belt and checked the main pulleys first, water pump, ac, alt. etc. Turns out its the tensioner arm pulley. Now i'm stuck i dont know how to replace it. Do i just undo the bolts? Any help would be greatly appreciated.
Thanks Guys
Patrick
Old 08-10-2008, 11:43 AM
Bobby82490's Avatar
Bobby82490
Bobby82490 is offline
You should to just to be able to unbolt it and run down to the local Napa or similar and get a new one.
Old 08-10-2008, 01:35 PM
lariat97's Avatar
lariat97
lariat97 is offline
Its a easy change. remove the belt & take the bolts out. I changed mine in no time at all.
mikeclinch
6.4L Power Stroke Diesel
09-28-2012 04:29 PM
SHOpar
34
06-15-2012 11:44 AM
eigenvector
1983 - 2012 Ranger & B-Series
09-25-2006 09:44 AM
cfd29
Modular V10 (6.8l)
11-17-2005 10:14 AM
Quick Reply: Removal of tensioner arm pulley
