2005 f250 key fob program - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 08-09-2008, 07:58 AM
tractorman41 tractorman41 is offline
tractorman41 is starting off with a positive reputation.
hi all i have a f250 superduty super crew with 5.4 engine i tried the 8 times key on off and the truck does go into program mode the doors don't lock on 8th turn did it alot off times nothing any help please thanks
Old 08-09-2008, 08:10 AM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
I found the instructions in the owners manual for my 05 and it worked perfect. I think you'll find under keyless entry in the index
Old 08-09-2008, 08:21 AM
only problem is i don't have a owners manual didn't come with the truck just bought it from far away
Old 08-09-2008, 08:45 AM
wiingnut's Avatar
this is from my 08 manual.
1. shut all doors and unlock electronically
2. put key in ignition
3. cycle 8 times rapidly (within 10 seconds) from position 1 (off) on the ignition to position 3 (on) Note: the 8th turn must end with the 3 (on) position. The doors will lock, then unlock, to confirm programming is activated.
4. Within 20 seconds press any button on key fob. Note: if longer than 20 seconds you will need to repeat previous steps.
5. Repeat step for for each key fob.
6. turn ignition to off position after you have programmed all key fobs. The doors will then lock and unlock to confirm.
7. good luck
Old 08-09-2008, 10:30 AM
i di that truck will not go into program mode on 8th time doors don't lock and if i put it in gear the doors don't lock
Old 08-09-2008, 10:38 AM
NorCalBusa NorCalBusa is offline
NorCalBusa is starting off with a positive reputation.
Ah- the 8 times thing is to add a new remote to the keyless entry. Sounds like what you are trying to do is enable/disable the autolock?
Old 08-09-2008, 10:49 AM
i was tring to get my remote to unlock the doors but it won't tried 8times thing but nothing
Old 08-09-2008, 11:32 AM
WildWildWest's Avatar
WildWildWest WildWildWest is offline
WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.WildWildWest has a great reputation on FTE.
Are you sure you have that option on your truck? Did it come with the keyfob remote? or are you just trying to add one, if so, you may not have the built-in components. Or batteries dead in remote, maybe.
By the way, Welcome to FTE!!
Here's a link to the 2005 owner's manual
http://www.analogstereo.com/pdf/om/f...anual_2005.pdf
Old 08-09-2008, 12:50 PM
the guy that sold it said the key fob didn't work and got one from another truck and said i would have to program it and how would i know if it has the option it is a 2005 xl f250 4x4 super crew power windows lock mirrors etc
Old 08-09-2008, 01:16 PM
wiingnut's Avatar
xl may not have it
Old 08-09-2008, 01:18 PM
if not i will use the key not a real big deal never had one on my old truck so nothing special thanks guys
Old 08-09-2008, 01:23 PM
I checked the 2005 MY-F250 PDF I have that shows all the standard and optional equipment on all models for 2005 and the key fob remote was only available on the XLT (optional) and Lariat and up models (standard) with the Advanced Security Group (60F) and that comes with the keypad entry on the outside of the door.
Your XL has the Power Equipment Group (903) and that didn't come with the key fob entry from the factory.
So, unless your truck was upgraded or special ordered with a key fob entry which was the Advanced Security Group (and Ford says that wasn't an option on the XL) it looks like the guy that sold it to you is full of crap.
Old 08-09-2008, 02:26 PM
thanks for the info atleast there is nothing wrong with the truck i will just key the lock thanks again
Old 08-11-2008, 12:32 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.Beerstalker has a very good reputation on FTE.
Do you have the numeric keypad on the side of the door? If not then you don't have remote keyless entry (the keypad was included in the remote keyless entry option from 05-up).
Sounds like WildWest found something saying you couldn't get the option on XL trucks though, so he is probably right. I just wanted to add this information so you could be sure, and others finding this thread in a search would know.
Old 08-11-2008, 05:25 PM
no i don't have a key pad on the door i must not have keyless entry thanks everyone
Key fob question Mattsn 1999 to 2016 Super Duty 9 07-04-2015 05:50 PM
08 Ford Escape RKE programming error dukkman65 Escape & Escape Hybrid 0 12-11-2014 07:11 PM
Programming new remote for 2004 F350 Number21 1999 to 2016 Super Duty 12 12-20-2013 12:22 PM
Factory remote start doesn't work after new keys LucasMN 1997 - 2003 F150 3 10-12-2012 11:36 AM
Key fob programming problem stash46 1999 to 2016 Super Duty 3 11-26-2011 01:49 PM
Tags
05, 2005, 2008, f250, fob, ford, key, keyfob, mode, pad, program, programming, reprogram, sink, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
