Gateway laptop with Vista...?
A gal at work asked me to look at her laptop, (Gateway MT3705 running Vista)it was freezing and /or running very slow.After about 2 minutes, it would just stop responding to everything except moving the mouse pointer.
In short, I narrowed the problem down to something in her sons profile. Any time I got near that folder, the the machine would come to a screeching halt. I was able to delete his profile and that helped, but it was still unstable.
I ran the Gateway system restore from the boot menu and had it back up her profile. It worked fine for a while but then started lagging badly.
I backed up her data (documents, pictures, etc) onto a CD and did a "factory" restore of the laptop. It boots much faster, but...it only created the disabled Administrator and User accounts!! There was no prompt to create a user account during the final stages of the process.
I repeated the restore 3 times thinking that I just missed something along the way or something silly like that. (I'm very unfamiliar with Vista) Nope. The restore process starts and finishes without user input, and I wind up at a login screen. Logging in as Administrator or User indicates the accounts are disabled. Others just indicate an invalid username or password.
I can get to a command prompt in the Gateway recovery panel. Is there any to add a user account from a command prompt? Any other ideas? I'm stumped.
That was a very early thought. I avoid Vista like the plague. There are NO XP drivers for this machine. From what I've read, Gateway does that quite often.
It is probably not doing a full install just more of a repair..
And I totally agree Vista Sucks big time..
My experience with Vista has been limited so far. I can say, though, that none of it has been a positive experience. I usually chalk it up to my lack of familiarity, but...
It supposedly formats the Windows partition and restores the system to it's "out of box" configuration. OOB, it should prompt you to create a user account at first boot, but it doesn't. It isn't the Windows System Restore utility. It's a third party utility provided by Gateway. You access it via the (F-8) boot menu.
The Gateway system recovery is usually started by pressing F10 or ALT+F10 or from a Gateway CD.
Folks are amazed when they do the math. 567cid per cylinder x 12 cylinders x 2 engines= 13,608 cid.
on
1 Post
Got a better idea - Linux.
I have a 2003 HP laptop that came with XP SP1. Windows aged out the driver for the ehternet card (which they often do for certain hardware - kinda forces a refresh)
It became unrunable.
Put on Ubuntu Linux 8.4 - it runs like a top. I have open office which runs with all windoze files, I have a Mp3 player and a chat program that recognizes all the file formats. And I have 'WINE' which runs windows aps.
Cost: $Free
Cost: $Free
There are options that let you do a (Windows) System Restore, but there were no restore points set. There are other selections like a memory test and a "startup problem repair". (It found no problems, natch).
The last option is the Restore Manager that restores the system to the OOB Gateway configuration. That's what I was trying for.
Cost: $Free
Cost: $Free
On a typical users computer, NFW. I'm not a teacher, and there IS a learning curve.
I work in a Windows environment, I don't think a large retail corporation is going to switch to Ubuntu any time soon. Microsoft has that market just about sewn up. (Although, we DO have POS controllers running IBM OS\2. When is the last time you heard THAT name?)
Open Source is a very good way to go, but it's very nature severely complicates use in a corporate environment. You can't go back to the "producer" for support. Corps aren't made up of computer geeks, they are made up of a collection of mostly clueless users with an IT support staff.
on
1 Post
Twas a shame, in the days of Win 3.11 and 95/98 OS2 was superior and in the days os ISA/EISA/VESA, MCA was superior.
