What's the deal with the tailgate lock?
OK, This may be a stupid question but here goes. When I shut my tail gate two or three times it automatically goes into lock mode. SO I got to go shut my truck off and unlock it then its good for two or three times opening and closing and then it does it again.... I did go and have a spare key made and put it on my other key ring so I don't have to keep shutting and starting my truck. but Is this normal or is there something wrong? I have been driving a bowtie truck for a while, so this is my first ford truck since I drove my dads 79 supercab in highschool. It is a 2000 F350 4x4 CC, long bed with the 7.3L.
Welcome to the club!
I didn't know that the tailgates lock automatically? I wonder if from shutting it so many times that it works itself into lock?? Maybe something has worked loose inside.
At least yours works! I got a tonneau cover for my truck a year ago and thought that it was great that the tailgate was lockable, that way I could lock it up and no one could get into the back end. But I can't get the keylock to turn!
I pulled all the guts out and cleaned them to see if anything was broke and all looks OK. But It still does it. Its a minor annoyance but when I'm trying to load the dogs it is a pain in the .... to have to pull my keys out. I got soaked in the rain just a few hours ago beacuse It was locked when I was trying to get my Lab to load up. Of course If I didn't have it jacked up I wouldn't have to lift him up into the back!
on
^^^^^^ what he said..word for word...
Mine acts the same way. Works when it wants to. Hate it, don't know what to expect. Want to rip the guts out for good. But with my luck someone will steal it so i leave it alone.(or will be the time it didn't lock and they walk off with it) I just got used to carrying my keys to it when i am going to open it. (need key or don't you) I think with mine it depends how hard i slam it shut.
Mine did that. It ended up being dirt and gunk on the latch mechanism preventing the pivot from reaching the full "unlock" position. I pulled the latch mechanism out of the tailgate and cleaned it up with a wire wheel on a dremmel tool. It's been fine for the last 8 months or so.
Before
After
You'll notice the round disc looking thing didn't pivot all the way down in the first picture when turning the key. I spent an hour debating with myself about adding some lubricant to the slide portion fearing it would pick up dust and cause it to stick again. In the end I added a couple of drops to help it move freely, and so far so good.
You'll need to remove the inspection plate cover from inside the tailgate to access this. If you have a spray in bedliner, you'll need to use a razor knife to cut the liner around this plate and the screws.
Before
After
Take it apart and have a look at it. See if the key turns with the handle removed from the tailgate so you know if it's the lock cylinder or the mechanism it attaches too. There's a good chance it just needs to be taken apart and the little lever on the back of the cylinder needs to be rotated. It may have turned too far one time and is not jammed on the wrong side of the mechanism.
Here's what the back of the lock cylinder looks like.
Not that much to it.
Yea I know Jacob, but you know what it's like to live in the middle of nowhere. I didn't have any on hand and figured I'd use a little oil since I would have to put it together and take it apart again if I made a run to get some.
It's lasted this long, but I'll use the graphite if it starts locking itself again.
