Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-08-2008, 01:40 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Freightrain is gaining momentum as a positive member of FTE.
6cyl flywheel ring gear?
Anyone have a source for a new one? How about a good used one?
Have a friend with junk ring gear and it's really a pain to start car sometimes. Most searches have come up empty. V8 stuff is plentiful, but not sure how interchangable it is?
Any help would be great.
__________________
*signature delete option*
  #2 (permalink)
Old 08-10-2008, 12:19 AM
fixnair fixnair is offline
fixnair is gaining momentum as a positive member of FTE.
Is it worn on one side only? I have several times in my life removed the ring gear, turn it over and heat it up with a propane torch, just to where it boils spit, and it will drop right back on with a new surface facing the starter.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
  #3 (permalink)
Old 08-11-2008, 08:56 AM
Well, haven't actually seen it yet. Not sure if worn or has missing teeth. I was going to flop it for him once he gets it apart, but would like to know if they make a new one in case we need it.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
