#6 cylinder misfire, completely stumped
Ongoing issue for a week and a half now. Always the same thing, loss of power, cutting in and out, when I pull the codes, it's always cylinder misfire #6 cylinder. I put a brand new spark plug in. I replaced the coil. I pulled the injector, hooked it up to a spare fuel pump with some rubber hose and gave them both the juice, it was spraying just fine. Still got the same code. So I put the #5 cylinder's coil and injector on #6, and still getting the same code. So I ran a compression test. 170psi. I inspected the wiring going to both the coil and injector, no cuts, the pigtails are in good condition, the wires aren't loose inside them, they still have the rubber insulators. So I set a screwdriver across the coil while I cranked it, and it was sparking like crazy, so I have spark for sure. Then I started the truck and listened to the injector with a screwdriver, I could hear it opening and closing just fine. So I have spark, I have fuel, I have compression, and I have air. But STILL it runs rough, and I get the CEL with the cylinder misfire code. Dudes I am completely stumped on this. All I know is I do NOT want to have to take it to Ford. ANY ideas what else I should check? Thanks!
Do you have a simple hand held scanner or something with more features?
I've used autotap, but there should be others that can offer: if any injector shorts, miss count, cumulative cylinder miss fire, O2, MAF and EGR. Everything is testing fine out of the vehicle, but when together there is something wrong with that cylinder. Did you check any other cylinders for compression? Was that a leak down or just compression test?
No I don't have a scanner for my truck. My friend has a pretty extensive diagnostic system that he runs from his laptop. I think we're gonna try and hook it up to that and run an injector test among other things.
It was just a regular compression test. I know you're supposed to test several cylinders, but when I saw it was 170, I knew the compression was fine.
A compression test of one cylinder will only tell you if you have compression on that particular cylinder. All cylinders should be checked and compaired against each other. I haven't done a compression check lately, but 170 sounds a little high. You might have a broken valve spring.
JL
Bear, I'm sure an intake leak would cause a miss. But I'm stumped cus it's ONLY on number 6. If it were a vacuum leak, intake leak, fuel problem, I would think that it would show up across the board ya know? Not just number 6. I had a 5.0 Mustang for several years that I had to track down a vacuum leak that caused it to run poorly, but it was all cylinders ya know?
Bobby, yea I'm gonna get together with my friend this week and see what the computer tells us. It'll pulse each injector individually while the motor is running to see if one is not working right. So hopefully I'll find something.
Went to a mechanic buddy that worked at a Ford dealership a while back. He looked it over and said that if it's not drinking coolant (meaning the intake gasket or head gasket), then it's probably a fatigued valve spring. He suggested pulling the schrader valve outta my compression gauge then leaving the gauge in the head while running the motor to see what kind of actual numbers I'm running. At higher rpms the spring might not have enough tension to get the valve all the way closed in time. Makes sense I suppose. Although if you ask me, this seems kind of ridiculous for a truck with only 120k miles on it.
Out of curiosity, what does a valve spring replacement cost at fomoco? I don't have the tools to do it myself (nor the time).
You don't wanna even know how much the dealer will charge to R&R valvesprings.
JL
