Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2009 6.4L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-07-2008, 08:41 PM
Carl Lassiter is starting off with a positive reputation.
'08 F350 Brake upgrade
Currently drive a genII Tundra. Rotors are 13.8" and only need to stop an unladen weight of 5500lbs (7,000lbs loaded). Noticed rotors on '08 F350 SRW are 13.66" front and 13.39" rear. On F450, rotors are 14.53" and 15.35" rear.
Is it possible to get the dealer to fit the bigger OEM rotors to the '08 F350 FX4, PSD, CC, SB, SRW that I have my eye on. Truck has the 20" wheels so clearance shouldn't be an issue. With a loaded wight of more than 11,000lbs I'd rather have ultimate stopping power and I don't like to go aftermarket.
Has anyone done this? Are the calipers the same? Cost?
Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-08-2008, 12:04 PM
Could someone please offer up an answer?
  #3 (permalink)
Old 08-08-2008, 12:05 PM
  #4 (permalink)
Old 08-08-2008, 12:42 PM
powerstroker27 is starting off with a positive reputation.
if im not mistaken, the 450/550 is a 10 lug hub were as the 350 is an 8. I would think ud need the 450/550 hub to mount the caliper bracket and caliper to ur 350 and i doubt the hub rotor combo would just bolt up to the 350 axle. But idk, some one might prove me wrong
__________________
2004 F350 4x4 auto c/c lb: afe intake, 5in straght pipe, custom sct by SDT, power elbow, 6in lift, lin-x'd two tone line, 37x13.5x18's mud grapplers
2001 f250 4x4 6sd s/c Lb: 6637, zoodad, 5in straight pipe, overboost, dp-tuner
  #5 (permalink)
Old 08-08-2008, 01:55 PM
Quote:
Thanks. I'll investigate further, though dealers often know less than truck owners. How do you find the stockers?
  #6 (permalink)
Old 08-08-2008, 09:11 PM
jasfaa's Avatar
jasfaa is starting off with a positive reputation.
The stock brakes are fine. 22000 miles and I tow haul 24000 lbs often. Still have most of the break pads left. looked yesterday.
__________________
Current Vehicle
2008 F350 Crew Cab Long Bed 6.4L
No Mods
Past Vehicle
2004 F350 Crew Cab Long Bed 6.0L
Banks 4" Monster Exhaust w/Six Gun
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
