Wiring New Stuff
Old 06-19-2001, 10:58 PM
sparky's Avatar
sparky
sparky is offline
Wiring New Stuff
Old 06-07-2002, 11:00 PM
Syzle's Avatar
Syzle
Syzle is offline
Wiring New Stuff
Hey guys I've got a few questions.. I'm interested in installing strobe lights and possibly neons.. all they say is to wire to a 12v source.. well I'm wondering what is the correct procedure and place to wire in things like that? How would I do it? I've used my cigarette lighter wires before to run strobes but thats it, any suggestions?
Old 06-08-2002, 12:23 PM
1968F250LWB's Avatar
1968F250LWB
1968F250LWB is offline
Wiring New Stuff
The correct place to install depends on when you want them to have power. If you want power all the time I would wire them straight to the battery through an aftermarket fuse. If you want them to only have power when the key is turned on then you have to splice into something else that has power at that time. Be careful not to overload the rated amperage of the circuit you splice into though. Most circuits are rated way above what the device using it pulls though. (i.e. Radio ckt w/20A fuse in it. Radio will only pull like 10 or 12 amps) Hope this helps,
Russell
1968 F250 Lwb
300 CID I6
Ahhhgladius
New Member Introductions
06-10-2013 10:05 PM
ufvj217
04-26-2011 11:48 AM
PowerstrokeJunkie
70
10-15-2008 10:26 PM
atvs4rent
04-07-2008 06:55 AM
JustinSWeber
09-19-2003 11:30 AM
Quick Reply: Wiring New Stuff
