Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-07-2008, 04:41 PM
Layed Out 100's Avatar
Layed Out 100 is gaining momentum as a positive member of FTE.
A/C control problem
This has happened twice to me in the last couple of months, 2005 f-250 6.0 the display does not come on at all until I recrank the truck? Now my brothers truck is doing it. I have had electonic problems before with a 97 f-150 and the service department told me they would have to have it hooked up to their computer when it happens. I quess what I'm asking has anybody else had this happen to them and do you know if it leaves some kind of code for the ford place to see if I bring it to them with the ac still working?
__________________
05 f-250 crew cab 4x4 6.0 Harley Davidson, 1953 f-100
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-07-2008, 04:46 PM
PS. my brother truck is also a 05 f-250, with the both of us having this problem I fiqure it must be common. thanks in advance guys
__________________
  #3 (permalink)
Old 08-07-2008, 05:35 PM
bismic's Avatar
bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.bismic has a very good reputation on FTE.
Here is some old info I kept in my spreadsheet -
A/C not Working:
Your head unit is starting to go south. Sometimes turning the ignition off and then back on corrects it.
Another trick is to flip the headlamp switch from the "Off" position to the "Auto" on position. I typically leave my headlamp switch in the "Off" position, and on the rare occasions when the A/C controller appears to be "dead" after initial start-up, I flip the Headlamp switch back & forth and the A/C controller will come on.
Very common problem. Mine did the same thing the first week I owned my truck. Turn the head lights on and off 2 times and it will come back to life. I never took mine in to get fixed and I never had problems with it other than no display once or twice a year.
http://www.ford-trucks.com/forums/633549-a-c-display.html
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #4 (permalink)
Old 08-07-2008, 05:38 PM
Thanks I will try this the next time, and tell my brother this info also.
__________________
  #5 (permalink)
Old 08-08-2008, 01:44 PM
CAMPINGTOM is starting off with a positive reputation.
The head lamp trick worked on mine also. FWIW, since I got new batteries it has not happened. With the old batteries it happened about once per month. Coincidence?
  #6 (permalink)
Old 08-08-2008, 06:55 PM
Quote:
Interesting...mabe the heat has got to my batteries. I'm going to take it in next week and see if ford can fix it while its still under warrenty.
__________________
  #7 (permalink)
Old 08-08-2008, 07:44 PM
69cj is starting off with a positive reputation.
Mine did the same thing. They replaces the head (control) unit under warranty.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
